You are here: PSPad forum > Developer forum - new builds > Re: PSPad UNICODE 4.5.0 (2127) beta English
Posted by: pspad | Date: 2005-09-13 21:48 | IP: IP Logged
I found problem, if in files you search was some EXE.
I will exclude binnary files from search in files function
Posted by: raptor | Date: 2005-09-14 08:04 | IP: IP Logged
I'm sorry.
Posted by: tyzio | Date: 2005-09-14 15:38 | IP: IP Logged
Great editor. I have used it for half a year and it has become only better and better.
Nevertheless I would like to report some isse/comment.
1. Indent/Unindent Block is not working on current line (only cursor is placed there). With 4.3.3 version it works.
2. The backslash char / is not a proper comment for TCL/TK language
3. The capture output in external appl. for highlighter is not working for TCL interpreter. (In Tools window the capture output works). Different capture output mehanism?
BTW: Is any change that 'Numeric base translator' and 'Expresion Evaluator' could use none-modal Dialog windows or something like that. (the main winow was operable).
Thanks in advance.
Posted by: pspad | Date: 2005-09-14 18:01 | IP: IP Logged
ok
> language
What is wrong ? I don't know Tcl/Tk syntax
No, its same function. In highlighter settings only compiler catch youtput, not external applications
Posted by: Guillaume H. | Date: 2005-09-14 20:15 | IP: IP Logged
I'm not sure how I should report this, but I have a PHP file that only contains a class and its methods. Only two of the methods are shown in the tree. If this helps, the methods shown are named "CYMenu" (the constructor) and "init". The two that are missing are named "bind" and "set".
Should I post a link to the source or something?
And one other thing. I'm not sure it was intentionally coded like this, but personnally I'd like to have indenting like Visual Studio. That means if a line ends with "{" and you press Enter, the next line is indented by one more indentation. Then when you type "}" it automatically decrease the indentation by "one indent". It just seems natural to me. Crimson Editor also does this (it's not updated anymore, this is why I'm switching to PSPad).
And lastly, I have something on my wish list: true column mode. I know it has been mentionned before, but I will add my vote
Keep on the great work!
Posted by: displeisisfactap | Date: 2005-09-15 13:59 | IP: IP Logged
HTML multihighlighter bug
Try this...<?php ?>& l t ; (<< last characters w/out spaces)
...and see what happens when you click on it.
Posted by: tyzio | Date: 2005-09-15 16:10 | IP: IP Logged
Jan,
>> language
When backslash appears in code line, the rest of line is treated as a command by PsPad (highlighted like comment, etc..)
>No, its same function. In highlighter settings only compiler catch youtput, not >external applications
So in this case, any change for caputring output function for external appl. in highlighter settings, or shortcut for configured tools/application in Tools window e.g. F8, Alt_F8, etc.., or both?
And also I vote for ' indenting like Visual Studio' option/function.
Thanks.
Posted by: pbrico | Date: 2005-09-20 06:17 | IP: IP Logged
I find a little problem with the "Search" functionality. Working on a source, it is possible to search a pattern in the document with CTRL+F. Pressing F3 goes to the next pattern. That's OK
But when in the search dialog box, you select an old searching pattern (not the first one), PSPad goes to the first occurrence and the F3 key doesn't work anymore.
Posted by: DxGx | Date: 2005-09-20 06:56 | IP: IP Logged
> That's OK
yup that's the problem that bothering me too
Posted by: Lolo | Date: 2005-09-20 07:17 | IP: IP Logged
Me too. I hope it will be corrected in the next release.
Thanks in advance Jan
