You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2127) beta English
Posted by: pspad | Date: 2005-09-11 18:48 | IP: IP Logged
Markus wrote:
> Hi,
> I just noticed the following bug:
> When I execute the "Check HTML Code" command in the HTML menu,
> PSPad shows a list of errors and warnings in the log window.
> Now when I doubleclick on one of the errors or warnings, PSPad
> doesn't mark the error in the HTML document any more, nor does
> it scroll in order to make the line containing the error
> visible. In the version 4.3.3 this worked ok. This is not very
> serious, but I wanted to let you know.
Go to Highlighter settings and for HTML gighlighter in COmpiler settings choose Log Parser for TiDy
Posted by: pspad | Date: 2005-09-11 18:57 | IP: IP Logged
Yes, there is problem.
Posted by: pspad | Date: 2005-09-11 19:02 | IP: IP Logged
Read help and differentiate between mode Text -> HEX -> Text and open file directly in HEM mode
Posted by: Jody | Date: 2005-09-12 04:57 | IP: IP Logged
Jan,
Just want to make sure you understood.
When you double click a word enclosed by quotes in 2127 the quotes are selected also.
Thanks as always...
Posted by: Rocky | Date: 2005-09-12 14:35 | IP: IP Logged
I'm running Windows XP SP2. With neither a BACKSPACE nor a DELETE can I delete anything in version 2127. Those keys seem to lose effectiveness.
Posted by: pspad | Date: 2005-09-12 19:14 | IP: IP Logged
Program settings / KeyMap
Press default button
Posted by: Jon | Date: 2005-09-13 11:05 | IP: IP Logged
I downloaded 2127 and I am glad to say that the wordwrapping is miles ahead of what it was in 4.3.3.
However, I seem to lose my editor key bindings about once per day, and I think it may have something to do with using the "Direct Settings" button in the Settings dialog as it happened twice immediately after changing something there.
Not sure though.
Jon
Posted by: shidf | Date: 2005-09-13 16:35 | IP: IP Logged
very nice version and great work, the only thing is the speed(such as search, screen scroll, etc) is much slower compared with 4.3.3.
hope to improve it, and keep it small, efficient, fast, reliable.
thanks
shidf.
Posted by: pspad | Date: 2005-09-13 20:28 | IP: IP Logged
In next build it will be OK
Posted by: pspad | Date: 2005-09-13 20:30 | IP: IP Logged
I found problem with UTF-8 encoding. In encoding except UNICODE it works OK
In next build it should be ok
