You are here: PSPad forum > English discussion forum > Re: Error: Out of memory
Posted by: pspad | Date: 2014-09-05 18:18 | IP: IP Logged
I will extend dialog to show reason, why file isn't open.
Posted by: maki | Date: 2014-09-05 18:51 | IP: IP Logged
how to run PSPad with the parameter debug?
Posted by: pspad | Date: 2014-09-05 18:53 | IP: IP Logged
there is no debug mode.
Posted by: maki | Date: 2014-09-05 19:02 | IP: IP Logged
Test
AkelPad (64-bit) - open
WordPad (Windows 7) - open
Notepad2 - open
Notepad++ (32-bit) - open
UltraEdit - open
PSPad - NOT OPEN... How to "force" on the program for more information - why not open the file?
Edited 2 time(s). Last edit at 2014-09-05 19:04 by maki.
Posted by: maki | Date: 2014-09-05 20:04 | IP: IP Logged
delete..wrong post
Edited 1 time(s). Last edit at 2014-09-05 20:07 by maki.
Posted by: pspad | Date: 2014-09-05 20:24 | IP: IP Logged
maki:PSPad - NOT OPEN... How to "force" on the program for more information - why not open the file?
I wrote you, i will extend provided information to show reason why the file isn't open.
Posted by: maki | Date: 2014-09-05 20:32 | IP: IP Logged
How? I ask how to reproduce? This program can not debug, no logs, only a very limited and stupid message "Can not open file" this is really annoying.
Ok, I reduced text file to 77MB and is still not open.
Posted by: maki | Date: 2014-09-05 20:47 | IP: IP Logged
all Text files created in Powershell
Example:
gci -filter *.txt d:\ -r | % { $_.FullName } | select-string -pattern '\\Name.*?\\' > d:\list.txt
Edited 1 time(s). Last edit at 2014-09-05 20:48 by maki.
Posted by: pspad | Date: 2014-09-06 08:20 | IP: IP Logged
maki:How? I ask how to reproduce? This program can not debug, no logs, only a very limited and stupid message "Can not open file" this is really annoying.
OK. Again. In the future version I will extend message to show reason why file wasn't open.
What text editor provides you detailed debug info?
PSpad gives enough debug info for any exception. If file can't be opened, it isn't exception.
From next build you will see system message. It should be enough to tell you the reason why the file can't be open.
Edited 1 time(s). Last edit at 2014-09-06 09:34 by pspad.
