You are here: PSPad forum > English discussion forum > Multi-Line Search Add-On
Goto Page: PreviousFirst...5 6 7 8 9 10 11 12 13 14 15 ...LastNext
Posted by: vbr | Date: 2008-07-11 14:06 | IP: IP Logged
Lolo:Thanks vbr for this confirmation.
I hope you will be able to correct this small bug.
In any case, I really love PhReplace!
Thanks and have a nice day.
Hi Lolo, sorry for the misunderstanding, I may have caused with my reply. In any case I am not the author of phReplace. (I just use it quite regularly and sometimes also try to answer some questions regarding the usage, if I'm able to.). I think Paul aka phdesigner will have a look at this problem.
Edit:
I just found out, that single replace maybe fails at [ or ]; although the RE mode is unchecked, it may be somehow there.
Moreover trying to replace e.g. {2} in non RE mode seems to cause system some kind of error.
Using regular expression and escaping those metacharacters, i.e. \[ \] etc. works fine, but it's rather ineffective, if one simply copies a text to be replaced...
Maybe this could help a bit with tracing the error source...
Edited 1 time(s). Last edit at 2008-07-11 14:28 by vbr.
Posted by: Lolo | Date: 2008-07-16 09:36 | IP: IP Logged
Hi vbr,
Sorry for the misunderstanding
I have contacted the author of PhReplace.
Now let's hope he will be able to make a patch.
By the way, thanks for your investigation on this problem.
Have a nice day.
Posted by: phdesigner | Date: 2008-07-23 09:47 | IP: IP Logged
Hi All,
Please note version 1.4.3 has been released which fixes this issue.
Regards.
Posted by: tone007 | Date: 2008-07-29 09:03 | IP: IP Logged
I really like the idea as this is something I was struggling with as I have huge files to change and have to do the change to 5 lines 5000 times.
So I tried the "replace all" feature but it just goes into a hang mode for quite some time.
So I opted for the no brainer option of clicking on "replace" 300 odd times but after replacing it then gives me an error message
"Run-time error: 6: overflow"
Can you please help.
I had tried to solve this issue before coming across this add on by doing a find and then copy paste...I tried to do the copy paste using a macro...but since I dont know much about how to write scripts in the macro i was pretty much stuck....can you point me in a direction where I can do tutorials and learn more about writing scripts in macros.
You can email me at tone007@rediffmail.com
Appreciate all your help and support.
thanks in advance
Tony
Posted by: vbr | Date: 2008-07-29 10:07 | IP: IP Logged
tone007:I really like the idea as this is something I was struggling with as I have huge files to change and have to do the change to 5 lines 5000 times.
Hi, on huge files the replace might take some time, could you maybe post a sample data as well as the replacement?
I tried a dummy text
Quote:line 01 line 01 line 01 line 01 line 01 line 01 line 01 line 01 line 01 line 01
line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02
line 03 line 03 line 03 line 03 line 03 line 03 line 03 line 03 line 03 line 03
line 04 line 04 line 04 line 04 line 04 line 04 line 04 line 04 line 04 line 04
line 05 line 05 line 05 line 05 line 05 line 05 line 05 line 05 line 05 line 05
line 06 line 06 line 06 line 06 line 06 line 06 line 06 line 06 line 06 line 06
line 07 line 07 line 07 line 07 line 07 line 07 line 07 line 07 line 07 line 07
line 08 line 08 line 08 line 08 line 08 line 08 line 08 line 08 line 08 line 08
line 09 line 09 line 09 line 09 line 09 line 09 line 09 line 09 line 09 line 09
line xx line xx line xx line xx line xx line xx line xx line xx line xx line xx
... ca. 45000 lines
and the replacing
Quote:line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02
to
Quote:TEXT 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02 line 02
TEXT 03 line 03 line 03 line 03 line 03 line 03 line 03 line 03 line 03 line 03
TEXT 04 line 04 line 04 line 04 line 04 line 04 line 04 line 04 line 04 line 04
TEXT 05 line 05 line 05 line 05 line 05 line 05 line 05 line 05 line 05 line 05
TEXT 06 line 06 line 06 line 06 line 06 line 06 line 06 line 06 line 06 line 06
took approx. 7 minutes using phReplace 1.4.3
Maybe there other ways to achive this too.
The documantation to PSPad scripting is in the helpfile: Customize PSPad: Script
Macros are somewhat limited, but easier to use:
Help :: Working with PSPad: Macro
Edited 2 time(s). Last edit at 2008-07-29 10:10 by vbr.
Posted by: nexor | Date: 2008-07-29 12:16 | IP: IP Logged
simple task: remove all empty lines.
regexp matching an empty line is: ^\s*$
the phReplace is finding all lines as matching. it seems that it has some problems with beggining of line as
^\s
matches *every* white char in document
-o((: w-files.pl )o-
Posted by: tone007 | Date: 2008-08-01 08:16 | IP: IP Logged
Hey thanks for this tip on the help file. I'll go through this. Here is an example of the file I have:
COMPDAT
W1 18 1 1 1 OPEN 1*
4.452451E-003 2.438400E-001 5.035279E-001 0.000000E+000 1* Z 5.214233E+001 /
W1 19 1 1 1 OPEN 1*
4.532991E-003 2.438400E-001 5.061100E-001 0.000000E+000 1* Z 4.827184E+001 /
W1 20 1 1 1 OPEN 1*
4.524853E-003 2.438400E-001 5.033911E-001 0.000000E+000 1* Z 4.724831E+001 /
W1 21 1 1 1 OPEN 1*
4.467094E-003 2.438400E-001 5.036242E-001 0.000000E+000 1* Z 5.117605E+001 /
W1 22 1 1 1 OPEN 1*
4.481863E-003 2.438400E-001 5.053080E-001 0.000000E+000 1* Z 5.118749E+001 /
W1 23 1 1 1 OPEN 1*
4.469954E-003 2.438400E-001 5.039735E-001 0.000000E+000 1* Z 5.119254E+001 /
W1 24 1 1 1 OPEN 1*
4.466344E-003 2.438400E-001 5.035279E-001 0.000000E+000 1* Z 5.116889E+001 /
W1 25 1 1 1 OPEN 1*
4.465689E-003 2.438400E-001 5.035279E-001 0.000000E+000 1* Z 5.121421E+001 /
W1 26 1 1 1 OPEN 1*
W1 27 1 1 1 OPEN 1*
W1 28 1 1 1 OPEN 1*
W1 29 1 1 1 OPEN 1*
W1 30 1 1 1 OPEN 1*
4.532741E-003 2.438400E-001 5.061100E-001 0.000000E+000 1* Z 4.828777E+001 /
W1 31 1 1 1 OPEN 1*
4.451635E-003 2.438400E-001 5.035279E-001 0.000000E+000 1* Z 5.220020E+001 /
W1 32 1 1 1 OPEN 1*
7.547348E+003 2.438400E-001 1.001737E+006 0.000000E+000 1* Z 1.492991E+002 /
W1 33 1 1 1 OPEN 1*
W1 34 1 1 1 OPEN 1*
W1 35 1 1 1 OPEN 1*
W1 36 1 1 1 OPEN 1*
W1 37 1 1 1 OPEN 1*
W1 38 1 1 1 OPEN 1*
W1 39 1 1 1 OPEN 1*
W1 40 1 1 1 OPEN 1*
W1 41 1 1 1 OPEN 1*
W1 42 1 1 1 OPEN 1*
W1 43 1 1 1 OPEN 1*
W1 44 1 1 1 OPEN 1*
W1 45 1 1 1 OPEN 1*
W1 46 1 1 1 OPEN 1*
W1 17 1 1 1 OPEN 1*
WCONPROD
W1 STOP 1* 1* 1* 1* 1* 1* /
-- Set no of restart files, and set to give results viewer info only
RPTSCHED
FIP
RPTRST
BASIC=2 NORST=2 POT
DRSDT
TUNING
4.16667e-006 0.000335648 1.0E-9 1.0E-9 1.2 /
8* 1504.04 3008.09 /
TSTEP
1*4.1666667e-006
-- Period start time: 0
COMPDAT
W1 18 1 1 1 OPEN 1*
W1 19 1 1 1 OPEN 1*
W1 20 1 1 1 OPEN 1*
W1 21 1 1 1 OPEN 1*
W1 22 1 1 1 OPEN 1*
W1 23 1 1 1 OPEN 1*
W1 24 1 1 1 OPEN 1*
W1 25 1 1 1 OPEN 1*
W1 26 1 1 1 OPEN 1*
W1 27 1 1 1 OPEN 1*
W1 28 1 1 1 OPEN 1*
W1 29 1 1 1 OPEN 1*
W1 30 1 1 1 OPEN 1*
W1 31 1 1 1 OPEN 1*
W1 32 1 1 1 OPEN 1*
W1 33 1 1 1 OPEN 1*
W1 34 1 1 1 OPEN 1*
W1 35 1 1 1 OPEN 1*
W1 36 1 1 1 OPEN 1*
W1 37 1 1 1 OPEN 1*
W1 38 1 1 1 OPEN 1*
W1 39 1 1 1 OPEN 1*
W1 40 1 1 1 OPEN 1*
W1 41 1 1 1 OPEN 1*
W1 42 1 1 1 OPEN 1*
W1 43 1 1 1 OPEN 1*
W1 44 1 1 1 OPEN 1*
W1 45 1 1 1 OPEN 1*
W1 46 1 1 1 OPEN 1*
W1 17 1 1 1 OPEN 1*
c.a. 3000 times
And I need to change this to:
COMPDAT
W1 18 1 1 1 OPEN 1*
WCONPROD
RPTSCHED
FIP
RPTRST
BASIC=2 NORST=2 POT
DRSDT
TUNING
TSTEP
1*4.1666667e-006
COMPDAT
W1 18 1 1 1 OPEN 1*
Appreciate any response on how to solve this.
cheers
tone
Posted by: Ondrej Beran | Date: 2008-08-02 14:08 | IP: IP Logged
tone007:Appreciate any response on how to solve this.
FYI: I tried to design a regex for backward search to replace your original text in PSPad (4.5.4.2325), but with no success
OTOH, I can do it using MultiEdit and/or Eclipse.
Ondrej
Posted by: vbr | Date: 2008-08-02 19:34 | IP: IP Logged
tone007:Hey thanks for this tip on the help file. I'll go through this. Here is an example of the file I have:COMPDAT
W1 18 1 1 1 OPEN 1*
W1 19 1 1 1 OPEN 1*
COMPDAT
W1 18 1 1 1 OPEN 1*
/c.a. 3000 times
COMPDAT
W1 18 1 1 1 OPEN 1*
4.452451E-003 2.438400E-001 5.035279E-001 0.000000E+000 1* Z 5.214233E+001 //
WCONPROD
Appreciate any response on how to solve this.cheers
tone
Hi, I'm afraid, I couldn't find any viable solution for this task using PhHReplace or PSPad in general; I guess some specialised software might be more suitable for tasks like this.
Just to make sure I underestood well - you want to reduce some kind of data section between
"COMPDAT"
and
"/" - single slash on the line-beginning
so that only the first two lines from this section are retained - is it a correct interpretation?
(I'm not quite sure regarding the repetition are there ca. 3000 "data-lines" or that number of COMPDAT blocks ?)
Anyway, you may check the "List" and "list not matching" options of the search dialog, but I'm not sure, if it is possible to specify excluding regex for all not wanted lines ...
Sorry for not beeing able to help more effectively and specifically...
Edited 1 time(s). Last edit at 2008-08-02 19:38 by vbr.
Posted by: ellocco | Date: 2008-09-09 09:27 | IP: IP Logged
I need some examples, the site:
www.regular-expressions.info
is fine, but I still don't know how to add new lines
(\n or \u000D) with the replace feature.
e.g. Search Regular expression:
(aaa)
Replace Regular expression
\n$1\n
or
\u000D$1\u000D
or
\\u000D$1\\u000D
is not working.
So what is the trick?
Regards
ellocco
