You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (731) English
Posted by: PaulPic | Date: 2022-05-13 13:05 | IP: IP Logged
caught in flagranti
Maybe gif gives a hit at where to look at.
git diff shows
PSPad shows
current version
Happened via automatic local git commit triggered by cron.
By the way:
This bulletin board is a bit out of date. An easy way to transmit images would be very much appreciated. Stackoverflow does it via simple Ctrl+v. img links to cloud services had all some problem.
Posted by: pspad | Date: 2022-05-13 15:46 | IP: IP Logged
Why did you publish it into 5.0.7 version when you screenshot is from previous 5.0.6 version?
Posted by: PaulPic | Date: 2022-05-27 11:32 | IP: IP Logged
Sorry,I just noticed myself right now. So it goes to show that this bug sticks around for a while now.
And of course it must read Maybe git gives a hit at where to look at. As the screenshots reveal, there are characters recorded by git which are not shown by PSPad. So I would suggest you look for the character sequence ^@.
Posted by: PaulPic | Date: 2022-05-27 11:46 | IP: IP Logged
This delay in our conversation shows that the default should be to send replies anyway. Even if I check "send replies" and then call preview the checkmark is gone so it will happen easily that the sender will not be in the loop.
Posted by: DARO75 | Date: 2022-07-28 01:30 | IP: IP Logged
Dobré ráno,
PSPad-IDE-Stil Windows only! no dark style?
Děkuji a zdravím
