You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (665) English
Posted by: pspad | Date: 2021-07-08 18:48 | IP: IP Logged
Ravelli:Can I send it to you via email? It contains some private information...
Friendly greetings
Ravelli
Yes, of course you can send it via support mail
Posted by: John Huijsing | Date: 2021-07-09 05:25 | IP: IP Logged
Tried open a file which has association with pspad
Exception description:
Division by zero.
Exception class: EDivByZero
Exception address: 00000000009068E4
Stack list, generated 9/07/2021 13:14:21
[00000000009068E4] SynEdit.TCustomSynEdit.PixelsToRowColumn (Line 1159, "SynEdit.pas" + 1) + $C
[0000000000866B98] JclDebug.JclCreateStackList (Line 5351, "JclDebug.pas" + 1) + $3F
[0000000000866B06] JclDebug.DoExceptionStackTrace (Line 5292, "JclDebug.pas" + 20) + $15
[00000000008690F2] JclDebug.DoExceptNotify (Line 6741, "JclDebug.pas" + 7) + $0
[00000000008568C5] JclHookExcept.TNotifierItem.DoNotify (Line 272, "JclHookExcept.pas" + 5) + $11
[0000000000856B0B] JclHookExcept.DoExceptNotify (Line 339, "JclHookExcept.pas" + 13) + $2B
[0000000000856CC7] JclHookExcept.HookedExceptObjProc (Line 395, "JclHookExcept.pas" + 5) + $0
[00000000004114CE] System.@DelphiExceptionHandler + $26E
[00007FFA913D217F] Unknown function at __chkstk + $11F
[00007FFA91381454] RtlRaiseException + $434
[00007FFA913D0CAE] KiUserExceptionDispatcher + $2E
[000000000091F125] SynEdit.TCustomSynEdit.UpdateMouseCursor (Line 8598, "SynEdit.pas" + 3) + $F
[000000000091E309] SynEdit.TCustomSynEdit.WMSetCursor (Line 8304, "SynEdit.pas" + 4) + $C
[0000000000410025] System.TObject.Dispatch + $45
[00000000007FD8E0] Vcl.Controls.TControl.WndProc + $370
[0000000000804B40] Vcl.Controls.TWinControl.WndProc + $9A0
[0000000000918BAB] SynEdit.TCustomSynEdit.WndProc (Line 6609, "SynEdit.pas" + 8) + $0
[0000000000803CBC] Vcl.Controls.TWinControl.MainWndProc + $2C
[000000000055B6C6] System.Classes.StdWndProc + $26
[00007FFA8FE5E858] Unknown function at CallWindowProcW + $3F8
[00007FFA8FE5E3DC] Unknown function at DispatchMessageW + $39C
[00007FFA8FE70BC3] Unknown function at SendMessageTimeoutW + $143
[00007FFA913D0C54] KiUserCallbackDispatcher + $24
[00007FFA8F051064] NtUserPeekMessage + $14
[00007FFA8FE5A5C3] Unknown function at PeekMessageW + $1E3
[00007FFA8FE5A523] PeekMessageW + $143
[00000000007B8F91] Vcl.Forms.TApplication.ProcessMessage + $71
[00000000007B90C8] Vcl.Forms.TApplication.HandleMessage + $18
[00000000007B9516] Vcl.Forms.TApplication.Run + $E6
[0000000000DBF95C] PSPad.PSPad (Line 120, "" + 57) + $0
[00007FFA90DE7034] BaseThreadInitThunk + $14
[00007FFA91382651] RtlUserThreadStart + $21
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.7 (663)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2200 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_X72312472"
Posted by: pspad | Date: 2021-07-09 07:03 | IP: IP Logged
Ravelli:Hi Jan,
I copied a chat-log from a website to PSPad to read it better. Turned out, with word-wrap enabled I can make the "un-wrapped" lines visible again by selecting the line into the "wrapped" line. But it doesn't always work. And I don't know what is causing it. I made example file, screenshot and a tiny video. Can I send it to you via email? It contains some private information...
Friendly greetings
Ravelli
Thank you for video. I see now. Problem is with highlight selected occurences. It doesn't count with wordwrap mode.
Posted by: MadCompie | Date: 2021-07-15 14:55 | IP: IP Logged
Me too an error...
When closing a file (which was opened via Windows file explorer) I got "list index out of bounds (296)"
I close the file by double clicking on the file tab.
There were no other files openened at that time...
Posted by: pspad | Date: 2021-07-15 15:00 | IP: IP Logged
I hope it's fixed already. I tested it now with no error.
