You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (665) English
Goto Page: 1 2 Next
#1 PSPad unicode 5.0.7 (665) English
Posted by: pspad | Date: 2021-07-07 18:24 | IP: IP Logged
Download links:
SHA1 hash: 5088daacc2444f2cf4c81df3f006c2e398936867 pspad507b665.zip d6f330a8998e52dd5eac0c9ac6ca8b75544ef0a0 pspad507b665x64.zip
Changes to 5.0.7 (659)
News:
In splitted window bookmarks are synchronized
Added mechanism what fix corrupted PSpad.INI file
FileTabs visibility when you close all files and open several files using OpenDialog
Windows shell script - variable %~xx highlighting
Paste the copied text into Excel
Autorefresh symbol on file tab
Activate window when file was already open
Other fixes reported by users
Known issues:
#2 Re: PSPad unicode 5.0.7 (665) English
Posted by: Ilya | Date: 2021-07-08 06:52 | IP: IP Logged
A new strange problem is here - a just open file gets the active tab's mark - orange upper line - after 20-30 seconds..
In other words - the Editor's part shows the content of an opened file, but the orange line is still above another tab.
#3 Re: PSPad unicode 5.0.7 (665) English
Posted by: pspad | Date: 2021-07-08 06:56 | IP: IP Logged
Your operating system please?
#4 Re: PSPad unicode 5.0.7 (665) English
Posted by: Ilya | Date: 2021-07-08 08:12 | IP: IP Logged
Win10 64bit
#5 Re: PSPad unicode 5.0.7 (665) English
Posted by: pspad | Date: 2021-07-08 09:34 | IP: IP Logged
I will force tab repaint after file open
#6 Re: PSPad unicode 5.0.7 (665) English
Posted by: MadCompie | Date: 2021-07-08 10:05 | IP: IP Logged
Hi, a small issue: when opening a COBOL file, the new code folding dotted lines seems to be random? And the codefolding menu items are all disabled.
Perhaps there should also be an option to enable/disable codefolding?
#7 Re: PSPad unicode 5.0.7 (665) English
Posted by: pspad | Date: 2021-07-08 10:11 | IP: IP Logged
Dotted lines are guided lines only. It helps readability, nothing else.
You can disable codefolding or guided lines only in the program settings / Code folding (section under editor part 2)
#8 Re: PSPad unicode 5.0.7 (665) English
Posted by: MadCompie | Date: 2021-07-08 13:35 | IP: IP Logged
thx for the settings tip
but the dotted lines don't follow any logics
like javascript it is okay i.e. if { ... }
but in cobol not, lines seems to be random and also no folding possible?
in some previous versions ago, it worked
#9 Re: PSPad unicode 5.0.7 (665) English
Posted by: pspad | Date: 2021-07-08 14:09 | IP: IP Logged
MadCompie:
Guide lines follows tabs width, maybe there is some other logic too.
Cobol code folding supports some basics things like divisions, sections... It's hard to do for Cobol, cause there is no END of division or sections, but simple start of new section
#10 Re: PSPad unicode 5.0.7 (665) English
Posted by: Ravelli | Date: 2021-07-08 15:45 | IP: IP Logged
Hi Jan,
I copied a chat-log from a website to PSPad to read it better. Turned out, with word-wrap enabled I can make the "un-wrapped" lines visible again by selecting the line into the "wrapped" line. But it doesn't always work. And I don't know what is causing it. I made example file, screenshot and a tiny video. Can I send it to you via email? It contains some private information...
Friendly greetings
Ravelli
Goto Page: 1 2 Next
