You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (655) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 5.0.7 (655) English
Posted by: pspad | Date: 2021-06-18 06:17 | IP: IP Logged
Download links:
SHA1 hash:
367bc89df504d7170a9b19ea88500ce1033ffe23 pspad507b655.zip
ef7530eed7c579c18b967c8bf6c7aa06cf38b4e9 pspad507b655x64.zip
Changes to 5.0.7 (651)
News:
Reverse apostrophe in user highlighter isn't autocompleted if isn't set is as string delimiter
JavaScript - added missing keywords
Split same window horizontally/vertically set second window into same position as the first one
Coment/Uncomment block (Shift+Ctrl+A) doesn't include last selected line in case the line contains 1 char only
Autocorrect doesn't work for files open with PSpad start
Other fixes reported by users
Known issues:
#2 Re: PSPad unicode 5.0.7 (655) English
Posted by: Greg | Date: 2021-06-18 20:51 | IP: IP Logged
Hello Jan,
Thank you for "Comment/Uncomment block", that's a small thing but i had to debug several times because of that :p
I saw something, i guess it's intended but i wanted to ask :\
I often use PSPad to prepare code with macros before copy-paste it in programs like MS Excel and i'm not interested in other stuff like Police Color but now when i copy/paste from PSPad it's with plenty of others caracteristics.
Is that a bug ?
#3 Re: PSPad unicode 5.0.7 (655) English
Posted by: pspad | Date: 2021-06-19 03:30 | IP: IP Logged
Other charactetistics?
What do you mean? Any example?
#4 Re: PSPad unicode 5.0.7 (655) English
Posted by: Greg | Date: 2021-06-19 10:22 | IP: IP Logged
I have 2 screenshots :
Edited 1 time(s). Last edit at 2021-06-19 10:22 by Greg.
#5 Re: PSPad unicode 5.0.7 (655) English
Posted by: pspad | Date: 2021-06-19 10:33 | IP: IP Logged
Do you mean points between words and paragraphs after line ends?
It is called whitespace chars and you see them, cause you enabled to see them.
Button on the toolbar with paragraph symbol or menu view / Special chars
If you meant anything else, please write it.
#6 Re: PSPad unicode 5.0.7 (655) English
Posted by: vbr | Date: 2021-06-19 11:54 | IP: IP Logged
it looks like, the clipboard copy contains richtext format from the highlighter in PSPad - however, I get similar results only by using File: Export: Export to clipboard as RTF;
using a simple copy, Ctrl+C, only plain text is copied to other apps, as expected.
Could it be possible, that the copy shortcut was somhow redefined for rtf export?
(It might also be some difference in windows versions, now I am testing this in win7.?)
regards,
#7 Re: PSPad unicode 5.0.7 (655) English
Posted by: bluezero | Date: 2021-06-19 12:11 | IP: IP Logged
Yes, i would prefer CTRL+C to copy only text without "richtext" too.
Or is there a setting for that already?
#8 Re: PSPad unicode 5.0.7 (655) English
Posted by: pspad | Date: 2021-06-19 12:19 | IP: IP Logged
Authors of the editor added HTML format for copy with highlighters.
I will try to persuade them to make it optional.
If not, I will switch it off in my editor component version.
I am trying to submit all my own component changes to github, but it's slow and long progress. I need to prepare it and persuade them to adopt it.
#9 Re: PSPad unicode 5.0.7 (655) English
Posted by: pspad | Date: 2021-06-19 12:29 | IP: IP Logged
What is most important for me now is stability feedback.
Do you see any exception, close up problems e.t.c.?
Is it beffer than before or there is no change and you meet is still often as before?
#10 Re: PSPad unicode 5.0.7 (655) English
Posted by: Greg | Date: 2021-06-19 16:30 | IP: IP Logged
I have less exceptions and i noticed a higher speed at the opening at b651.
(I talked about richtext on my first message : color, police, ... In this situation i have to copy-paste by Notepad after PSPad before sending it in another program. I did know about whitspaces and the way of showing them, it's done on purpose)
Edited 1 time(s). Last edit at 2021-06-19 16:31 by Greg.
