You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (649) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-11 18:20 | IP: IP Logged
It means you call directly ecREDO from Editor commands? This is a new information.
I will check it.
aREDO and aUNDO are disabled when there is no item in stack.
Editor commands call directly editor component. I must check how is it done there.
#22 Re: PSPad unicode 5.0.7 (649) English
Posted by: Professor Bernd | Date: 2021-06-12 15:16 | IP: IP Logged
Hello.
Maybe it has to do with the fact that in the KeyMap.ini various keys appear twice (ecUndo, ecRedo, ...) or even three times (ecLineBreak).
I created a fresh PSPad installation (5.0.5 (567) + 5.0.7 (649) beta), then assigned a shortcut to the first free entry in "Settings" / "Program Settings" / "Key Map" and saved the settings. This created a KeyMap.INI with the duplicate entries.
Maybe you could take the opportunity to change the upper case of the file extension ".INI" for all newly created .ini files to lower case ".ini"? winking smiley
#23 Re: PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-12 15:48 | IP: IP Logged
ecUndo and ecRedo is fixed in current 651 build
#24 Re: PSPad unicode 5.0.7 (649) English
Posted by: Greg | Date: 2021-06-12 22:16 | IP: IP Logged
Thank you !
(it seems it works fine with the two options in the next release)
#25 Re: PSPad unicode 5.0.7 (649) English
Posted by: Greg | Date: 2021-06-12 22:17 | IP: IP Logged
Oups, so you already said it ;)
