You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-07 16:37 | IP: IP Logged
Download links:
SHA1 hash:
cab963263c2cb314c813c703779bb47e06b63a92 pspad507b649.zip
9bb24b22e0e15bf4c9dcc0ab56ab092454f897f4 pspad507b649x64.zip
Changes to 5.0.7 (647)
News:
Scripting - new functions mainWindowHandle(): HWND, editorWindowHandle(): HWND
Fixed UNDO with active autoindent on the last editor line with real tabs
Fixed combination of Real tabs and smart tabs with Autoindent - unwanted spaces insertion
Fix of potential configuration corruption
Other fixes reported by users
Known issues:
Edited 1 time(s). Last edit at 2021-06-08 06:39 by pspad.
Posted by: Fred | Date: 2021-06-08 06:32 | IP: IP Logged
Hello Jan,
The pspad.poradna links to the 647 builds, not the 649 builds
Posted by: pspad | Date: 2021-06-08 06:40 | IP: IP Logged
Thank you for message, fixed
Posted by: Greg | Date: 2021-06-08 07:30 | IP: IP Logged
Hello Jan,
I think it's been 2 or 3 builds since i saw that lines wrapping doesn't work.
Edited 1 time(s). Last edit at 2021-06-08 07:30 by Greg.
Posted by: pspad | Date: 2021-06-08 07:41 | IP: IP Logged
Greg:I think it's been 2 or 3 builds since i saw that lines wrapping doesn't work.
hello
Line wraping works. Wrap position depends of right edge (vertical line on the right site) or window width.
Look into settings in Program settings / Editor 2
unncheck option Wrap with right edge, if you want to wrap with winfow width
Some users disable right edge line or set the position to zero or somewhere behind
Posted by: Professor Bernd | Date: 2021-06-09 00:28 | IP: IP Logged
Hello.
When I use Column Selection (Alt + left mouse button) I can select a vertical block. But I am not able to move the selection with the mouse. Am I doing something wrong?
Posted by: pspad | Date: 2021-06-09 04:06 | IP: IP Logged
Professor Bernd:Hello.When I use Column Selection (Alt + left mouse button) I can select a vertical block. But I am not able to move the selection with the mouse. Am I doing something wrong?
Thank you for report, I will look at it.
Posted by: Ravelli | Date: 2021-06-09 06:31 | IP: IP Logged
When comparing two files (text diff), and I move the vertical divider from right to left, then I get lots of black lines. Then vanish again, as soon I scroll text.
Posted by: pspad | Date: 2021-06-09 06:40 | IP: IP Logged
Thank you, fixed
Posted by: Greg | Date: 2021-06-09 10:00 | IP: IP Logged
Thank you for your answer Jan.
But i use it the righ way unfortunatly and it doesn't work here...
I'l send you a screen if you need. Or do you want something else ?
