You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (649) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-07 16:37 | IP: IP Logged
Download links:
SHA1 hash:
cab963263c2cb314c813c703779bb47e06b63a92 pspad507b649.zip
9bb24b22e0e15bf4c9dcc0ab56ab092454f897f4 pspad507b649x64.zip
Changes to 5.0.7 (647)
News:
Scripting - new functions mainWindowHandle(): HWND, editorWindowHandle(): HWND
Fixed UNDO with active autoindent on the last editor line with real tabs
Fixed combination of Real tabs and smart tabs with Autoindent - unwanted spaces insertion
Fix of potential configuration corruption
Other fixes reported by users
Known issues:
Edited 1 time(s). Last edit at 2021-06-08 06:39 by pspad.
#2 Re: PSPad unicode 5.0.7 (649) English
Posted by: Fred | Date: 2021-06-08 06:32 | IP: IP Logged
Hello Jan,
The pspad.poradna links to the 647 builds, not the 649 builds
#3 Re: PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-08 06:40 | IP: IP Logged
Thank you for message, fixed
#4 Re: PSPad unicode 5.0.7 (649) English
Posted by: Greg | Date: 2021-06-08 07:30 | IP: IP Logged
Hello Jan,
I think it's been 2 or 3 builds since i saw that lines wrapping doesn't work.
Edited 1 time(s). Last edit at 2021-06-08 07:30 by Greg.
#5 Re: PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-08 07:41 | IP: IP Logged
Greg:
hello
Line wraping works. Wrap position depends of right edge (vertical line on the right site) or window width.
Look into settings in Program settings / Editor 2
unncheck option Wrap with right edge, if you want to wrap with winfow width
Some users disable right edge line or set the position to zero or somewhere behind
#6 Re: PSPad unicode 5.0.7 (649) English
Posted by: Professor Bernd | Date: 2021-06-09 00:28 | IP: IP Logged
Hello.
When I use Column Selection (Alt + left mouse button) I can select a vertical block. But I am not able to move the selection with the mouse. Am I doing something wrong?
#7 Re: PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-09 04:06 | IP: IP Logged
Professor Bernd:
Hello.
Thank you for report, I will look at it.
#8 Re: PSPad unicode 5.0.7 (649) English
Posted by: Ravelli | Date: 2021-06-09 06:31 | IP: IP Logged
When comparing two files (text diff), and I move the vertical divider from right to left, then I get lots of black lines. Then vanish again, as soon I scroll text.
#9 Re: PSPad unicode 5.0.7 (649) English
Posted by: pspad | Date: 2021-06-09 06:40 | IP: IP Logged
Thank you, fixed
#10 Re: PSPad unicode 5.0.7 (649) English
Posted by: Greg | Date: 2021-06-09 10:00 | IP: IP Logged
Thank you for your answer Jan.
But i use it the righ way unfortunatly and it doesn't work here...
I'l send you a screen if you need. Or do you want something else ?
