You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (600) English
Posted by: PGomersall | Date: 2021-04-26 15:31 | IP: IP Logged
I see what happened, you changed the name of the log file from PSPUpdater.log to Update.log and I was looking at the old file name.
Posted by: bluezero | Date: 2021-04-26 15:55 | IP: IP Logged
I was closing a file. I am not using spell check.
I am using syntax highlighting, but the file i was closing was pure text file.
Not sure if that helps.
Posted by: Ravelli | Date: 2021-04-28 06:10 | IP: IP Logged
After opening a PHP file and reading it for some seconds, I got an error message, that PSPad is not working anymore, and a button to close the program. There was no access violation showing up. This happened occasionally also in previous versions. I had some other files opened. PSPad was running since three days, so since I updated to 600 I did not close it, and there were no other issues.
Posted by: pspad | Date: 2021-04-28 06:17 | IP: IP Logged
Thank you for report.
Can you please try 32b PSPad version? Replace PSPad.exe, libeay32.dll and libssl32.dll only.
Posted by: Ravelli | Date: 2021-04-28 06:21 | IP: IP Logged
Oh, I'm already in 32 bit, but under Windows 7 Pro 64 bit still, if that makes a difference. Should I still replace something?
Posted by: pspad | Date: 2021-04-28 07:13 | IP: IP Logged
No, in this case is it OK.
Posted by: mikeho | Date: 2021-04-28 12:55 | IP: IP Logged
Updating from 598 has lost my previous settings.
Posted by: pspad | Date: 2021-04-28 13:31 | IP: IP Logged
There should be PSPad.ini.bak file with your option as last correct backup
Posted by: bluezero | Date: 2021-04-29 10:10 | IP: IP Logged
While closing a file:
Exception description:
Access violation at address 004E886B in module 'PSPad.exe'. Read of address 000000FF.
Exception address: 004E886B
Stack list, generated 29/Apr/2021 12:10:00
[004E886B] System.Classes.TComponent.RemoveFreeNotifications + $33
[004E8694] System.Classes.TComponent.Destroy + $14
[006A24D1] Vcl.Controls.TControl.Destroy + $121
[00409914] System.TObject.FreeInstance + $C
[0040A07E] System.@ClassDestroy + $2
[006A1B07] Vcl.Controls.TControlCanvas.Destroy + $23
[006AFB9B] Vcl.Controls.TGraphicControl.Destroy + $2B
[006A715E] Vcl.Controls.TWinControl.Destroy + $D6
[0066A8F3] Vcl.Forms.TScrollingWinControl.Destroy + $4B
[0066B964] Vcl.Forms.TCustomForm.Destroy + $138
[00409A0C] System.TObject.Free + $8
[006719C0] Vcl.Forms.TCustomForm.CMRelease + $0
[006A5092] Vcl.Controls.TControl.WndProc + $2BE
[005B9C3F] Vcl.ComCtrls.TPageControl.WMLButtonDblClk + $33
[006A9FE7] Vcl.Controls.TWinControl.WndProc + $693
[0040A91C] System.TMonitor.TryEnter + $28
[0040A444] System.TMonitor.Enter + $10
[0066D074] Vcl.Forms.TCustomForm.WndProc + $6F0
[0040A2AC] System.TMonitor.CheckOwningThread + $4
[0040A5D2] System.TMonitor.Exit + $6
[0040A62E] System.TMonitor.Exit + $1A
[00541EFD] Vcl.Graphics.FreeMemoryContexts + $9D
[006A9534] Vcl.Controls.TWinControl.MainWndProc + $2C
[006A9549] Vcl.Controls.TWinControl.MainWndProc + $41
[004EAF14] System.Classes.StdWndProc + $14
[006A972C] Vcl.Controls.TWinControl.ControlAtPos + $10
[0066D05F] Vcl.Forms.TCustomForm.WndProc + $6DB
[00676EE7] Vcl.Forms.TApplication.ProcessMessage + $F3
[00676F2A] Vcl.Forms.TApplication.HandleMessage + $A
[00677261] Vcl.Forms.TApplication.Run + $C9
[00AD73ED] PSPad.PSPad (Line 119, "" + 55) + $7
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.7 (600)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz, 2590 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_X02731379"
