You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.6 (571) English
Posted by: Professor Bernd | Date: 2021-03-20 15:38 | IP: IP Logged
PSPad IDE Style "Windows 10 SlateGray".
To show the FavTools you should press Shift+Ctrl+X (File menu / Open Favourite). But if the FavTools are docked in the right panel, pressing Shift+Ctrl+X will show the left panel instead, the right one will remain invisible.
The only way I found to show the FavTools again after hiding them:
1. press Shift+Ctrl+X, the left panel is shown WITHOUT the FavTools. (Hide left panel again if it was hidden).
2. show another tool in the right panel, e.g. Alt+A for ASCII Table and hide it again.
The two steps must be done every time you hide the FavTools and want to show them again.
Posted by: Professor Bernd | Date: 2021-03-20 15:58 | IP: IP Logged
Bug is still there:
PSPad IDE Style "Windows 10 SlateGray". File Tabs Style: Tabs.
If you have a project with 2 rows of tabs, and you select a tab from the upper row, the row is moved to the lower row. If you close PSPad and restart the project, an exception is thrown.
Posted by: pspad | Date: 2021-03-20 17:51 | IP: IP Logged
Professor Bernd:PSPad IDE Style "Windows 10 SlateGray".To show the FavTools you should press Shift+Ctrl+X (File menu / Open Favourite). But if the FavTools are docked in the right panel, pressing Shift+Ctrl+X will show the left panel instead, the right one will remain invisible.
I didn't count you will close Favourite panel on the right side.
OK. ShowFavourite was fixed, now it will show favourite where you last docked it and set focus to favourite. You can close it from the left and show again.
