You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.6 (571) English
Posted by: pspad | Date: 2021-03-14 17:13 | IP: IP Logged
Download links:
SHA1 hash:
4422b741ad42c0538a2e1ccb065db4e51f314cfb pspad506b571.zip
8606c4cea892411dea29b093fc0aad5283075f35 pspad506b571x64.zip
Changes to 5.0.5 (569)
News:
Sessions (File menu, Toolbar button) - PSPad remembers last session. Last session is selected in Session manager, last session is marked in menu items with star icon
New version check was moved into separate thread - it doesn't delay program start
Left panel - you need to keep CTRL when you want to undock Window as protection for unwanted undocking
Add Accent marks function works on selected text. Till now always on whole text
Search/Replace - in some cases cursor appear out of editor area
Open big file without running PSPad - wasn't possible to confirm dialog with keyboard
Runtime error after PSPad is closed
Code explorer - if docked in left panel, left panel always appear after start
Posted by: gwinkless | Date: 2021-03-16 09:30 | IP: IP Logged
After a day or so's usage both my issues from 569 seem fixed, thanks
Posted by: ok1 | Date: 2021-03-17 12:36 | IP: IP Logged
Thanks for the startup fix! For me improved it from ~8 seconds down to 1.
Edited 1 time(s). Last edit at 2021-03-17 12:36 by ok1.
Posted by: pspad | Date: 2021-03-17 12:50 | IP: IP Logged
ok1:Thanks for the startup fix! For me improved it from ~8 seconds down to 1.
Great, thank for confirmation.
Posted by: Professor Bernd | Date: 2021-03-18 01:02 | IP: IP Logged
Start PSPad and keep an eye on the toolbar buttons "Save file" and "Save ... all", as well as the title bar (the asterisk for not saved) and the "Save" icon in the bottom bar.
type "a
press Ctrl+Z
press Ctrl+Z
press Shift+Ctrl+Z
press Shift+Ctrl+Z
type "abcd
press Ctrl+Z 4x
press Ctrl+Z
press Shift+Ctrl+Z 4x
press Shift+Ctrl+Z
Do you see anything wrong with the buttons? If you can't see any problems, I apologize. It's late and maybe it's just me.
Posted by: Professor Bernd | Date: 2021-03-18 14:33 | IP: IP Logged
I suspect the same bug as above: Undo and Redo do NOT bring the current line into the visible area.
After search/find the "highlight all occurrences" does not work anymore.
Posted by: pspad | Date: 2021-03-18 14:47 | IP: IP Logged
Professor Bernd:After search/find the "highlight all occurrences" does not work anymore.
Found and fixed. Thank you
Posted by: pspad | Date: 2021-03-18 14:53 | IP: IP Logged
Professor Bernd:HelloStart PSPad and keep an eye on the toolbar buttons "Save file" and "Save ... all", as well as the title bar (the asterisk for not saved) and the "Save" icon in the bottom bar.
type "a
press Ctrl+Z
press Ctrl+Z
press Shift+Ctrl+Z
press Shift+Ctrl+Ztype "abcd
press Ctrl+Z 4x
press Ctrl+Z
press Shift+Ctrl+ZDo you see anything wrong with the buttons? If you can't see any problems, I apologize. It's late and maybe it's just me.
The problem is in update only. If you move cursor, what doesn't make any changes in text, all is refreshed.
I will try to find reason why refresh doesn't occurs after undo/redo
Posted by: Professor Bernd | Date: 2021-03-18 17:04 | IP: IP Logged
PSPad IDE Style "Windows 10 SlateGray". When I open and close the PSPad about dialog, PSPad crashes. All changes are lost.
PSPad IDE Style "Windows 10 SlateGray". If PSPad is maximized on exit and I restart PSPad, the window is then also maximized (= ok). Then I restore the window to its normal size and minimize it to the taskbar. When I restore it from the taskbar, it is maximized again. - This happens every time: When I restore PSPad from the taskbar, it is maximized.
Thanks for the fixes.
Posted by: pspad | Date: 2021-03-18 17:28 | IP: IP Logged
Problem with about dialog was already reported and fixed. Wait for next build please
