You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.4 (511) English
Posted by: pspad | Date: 2020-06-21 21:54 | IP: IP Logged
Download links (5.4 MB):
SHA1 hash:
a1a57d29c2673b3c22a7a075671c511fb5728a44 pspad504b511.zip
749bbb1f7228640ad205e8aa8ff223a147cea758 pspad504b511x64.zip
Changes to 5.0.4 (509)
News:
Favorite panel / Tools - added option Save all files before tool starts
Status bar was moved to the bottom of main window from the bottom of individual windows. The reason is reading devices support for visually impaired people.
Tool panel - button size of the first toolbar
Posted by: Bobf | Date: 2020-06-22 15:55 | IP: IP Logged
Hello Jan,
i still have the problem with the restore from systray.
Open 3 Files, and set Pspad into Systray.
restore from Systray only one Tab is restored.
rgs Bob
Posted by: pspad | Date: 2020-06-22 16:09 | IP: IP Logged
hello
I am testing, playing with systray now and I am not able to simulate it.
Do you restore PSpad clicking on systray or clicking on PSPad icon or?
Do you open any other file before restore?
Are files local or on some share? If from share, ensure that Store from local drives option isn't checked in the Program settings / Files and dirs
Is there any stape by step to simulate it?
Posted by: Bobf | Date: 2020-06-23 09:21 | IP: IP Logged
hello Jan,
> open two TXT files from the same local drive like C:\test\Bob1.txt and Bob2.txt
> click on the X to move PSpad into the Systray
> on the Systray, right mouse click on PSpad and select -> "Restore last State"
> PSpad comes up, with only New1.txt and the other 2 TXT files are gone
Please keep in your mind i sent you already my pspad.ini
rgs Bob
Posted by: vuki | Date: 2020-06-23 09:57 | IP: IP Logged
Status bar is broken on high DPI devices - font is now HUGE. (Edit: 64 bit version)
Edited 1 time(s). Last edit at 2020-06-23 09:58 by vuki.
Posted by: pspad | Date: 2020-06-23 10:34 | IP: IP Logged
vuki:Status bar is broken on high DPI devices - font is now HUGE. (Edit: 64 bit version)
Thank you for info, fixed.
Posted by: pspad | Date: 2020-06-23 10:42 | IP: IP Logged
Bobf:hello Jan,> open two TXT files from the same local drive like C:\test\Bob1.txt and Bob2.txt
> PSpad comes up, with only New1.txt and the other 2 TXT files are gonePlease keep in your mind i sent you already my pspad.ini
rgs Bob
Hello Bob
I have your PSpad.ini from June 10, but it wasn't set to close PSpad into systray.
I activated the option in program settings / System integration, but same situation - after restore I got all my previously opened file. And I am sure it's your file, cause localization was in German after PSPad started.
Recent files are stored in the Recent.ini file. You can delete or rename it to test if there isn't any problem.
Posted by: Bobf | Date: 2020-06-23 12:55 | IP: IP Logged
Hello Jan,
it doesn't matter if Pspad is english or german,the behavior is still the same.
The Recent.INI file was good hint.
I opened pspad and the Recent.INI has 157 lines.
Then i opened two files, and expect them to see it in the ini or the number of lines goes to 159. but nothing.
I renamed the old one, and a new one was created, but same result
I use Pspad from the portable zip file (5.0.3 (377)) and use the zip from the beta.
As you can see from my Pspad.ini, it's not installed under "Program Files" or any other standard folder.
I use Windows 10(1909) Enterprise.
Which line would i see when i opened this two files?
Bob
Posted by: pspad | Date: 2020-06-23 13:02 | IP: IP Logged
Whwn you close PSPad, you should see it in the section [SaveWork]
This is the section with list of files what are restored.
And of course your files should appear in the [Recent] section as Item0 and Item1
Posted by: Bobf | Date: 2020-06-23 13:43 | IP: IP Logged
I had 36 Items in the Recent file list,
I cleared all these files -> Clear recent files list, and restarted pspad.
Opened two files and they are visible under [Recent] Item0 / Item1.
Minimize pspad to systray and restore it, pdpad comes with an empty NEWfile.TXT.
but the two files with the Item0 / Item1 are still under [Recent] in the ini file.
I have no [SaveWork] in the Recent.ini.
Do i need enable something to get the [SaveWork] ?
Bob
