You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.4 (407) English
Posted by: pspad | Date: 2020-05-23 17:33 | IP: IP Logged
Download links (5.4 MB):
SHA1 hash:
13691d373473fcbca64312487a6b0f1c82c3bbd6 pspad504b407.zip
8a73c74cbe892b199e2dc3346abe89ed8227c09c pspad504b407x64.zip
Changes to 5.0.4 (403)
News:
Skins - Program settings / Colors - is possible to change program skin to black. In the same place you can load Highlighters scheme. Optimized are PSPad_Light and PSPad_Dark. Creating and modifying schemes stays in Highlighter settings. As Skin is possible to use any Delphi VCL scheme (VSF extension).
Program settings / Colors - possibility to set color for other occurrence of selected text
Other occurences of selected text - changed to case insensitive, spaces on the begin/end are trimmed
Many optimalizations made for Load/Save highlighters scheme
Open/Save dialog work was rewrited (joined with skins). For Windows Vista and newer new system dialogs are used
Braceks highlight
Fixed another bugs joined to fast window Open/Close
Optimized redraw/flickering in window switching
Posted by: naputtelija | Date: 2020-05-25 04:46 | IP: IP Logged
pspad:Skins - Program settings / Colors - is possible to change program skin to black.
Thanks, works great!
Posted by: pspad | Date: 2020-05-25 04:51 | IP: IP Logged
There are still limitation like drop file to editor what must be solved. But I hope it will worth the time I spent with.
This version is "first shot" to get all problems, all forgotten formulars with wrong drawing e.t.c.
Posted by: MadCompie | Date: 2020-05-25 06:52 | IP: IP Logged
Good optimizations! Also I like "the save as to ftp" which directly saves to ftp now.
Yet a behaviour question :
pspad:Other occurences of selected text - changed to case insensitive, spaces on the begin/end are trimmed
Ex. 3 lines of text
TEXT1
TEXT2
TEXT3
If I search (or select) "tex" the following is displayed
TEXT1 (with TEX in default highlight color)
texT2 (with tex in alternate highlight color)
texT3 (with tex in alternate highlight color)
So the case of my text is changed? I think it is better to indeed select the match (case insensitive unless we specify it in the search modal) but not to change the case of the occurencies?
When leaving the selection, case is correctly restored
Posted by: pspad | Date: 2020-05-25 07:03 | IP: IP Logged
MadCompie:So the case of my text is changed? I think it is better to indeed select the match (case insensitive unless we specify it in the search modal) but not to change the case of the occurencies?
Hello. There is a bug, but in drawing only. It has no influence of text in documents.
Text is drawn as lowercased. It will be fixed in the next build.
Posted by: MadCompie | Date: 2020-05-25 11:11 | IP: IP Logged
top!
Posted by: MadCompie | Date: 2020-05-25 12:11 | IP: IP Logged
FTP file sort order does not work correctly...
Sort by name = ok
Sort by size = ok
Sort by extension = ok
Sort by timestamp = error
file1.. 25/05/2020 13:44:00
file2.. 25/05/2020 13:45:00
file3.. 25/05/2020 13:45:00
file4.. 25/05/2020 13:42:00
Strange...
Posted by: pspad | Date: 2020-05-25 12:31 | IP: IP Logged
In Date time compare were values truncated. I added more precision compare.
Posted by: MadCompie | Date: 2020-05-25 12:50 | IP: IP Logged
thx!
yet some other issue:
if a open a file with FTP and I do some changes with at other program + save in that program, PSPad does not longer detect that the file has been changed...
Posted by: pspad | Date: 2020-05-25 13:03 | IP: IP Logged
PSpad didn't detect changes on FTP server.
I can't imagine that I will check and download very big file listing from FTP server, reconect to few another servers, cause you can work with documents in several FTP servers together and check if file on FTP side was changed.
Especially when some FTP servers don't provide exact file date time.
If you change the file on the background, you know you did it.
If somebody else changes files you are editing on the background, than you should change your work style, cause FTP isn't good place for working together on the same files and there should be some step (versioning system) between real files and your modifications.
