You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.4 (407) English
Posted by: MadCompie | Date: 2020-05-25 13:25 | IP: IP Logged
Hi Jan, it did work until this latest release...
I guess the following happens:
1) opening a file with FTP : the file is "imported" in a temp folder somewhere in my local C:
2) doing some changes in the text
3) F12 = save as to this local file
or "save to ftp" or simply "save" = save back to FTP
point 2) seems to be missing?
with the other version the temp file was opened and after opening & saving it in an external program (ex. xml editor, comparer, ...) the temp file is changed and was detected by PSPad ; a dialog opened with the question to accept the external changes...
so indeed, no controls if a ftp source has changed but it should check the temp file?
practical example:
open ftp "ftp_file_1" (autom. into temp local file "TEMP_FILE1")
open ftp "ftp_file_2" (autom. into temp local file "TEMP_FILE2")
start file compare using external "diffmerge"
- compare is done between temp local files
- modify "TEMP_FILE2"
stop file compare
PSPad detected a file change (older versions)
but:
PSPad does not detect the file change (this latest version)
As a result, the file "TEMP_FILE2" is modified but PSPad does not show the changes...
Edited 1 time(s). Last edit at 2020-05-25 13:33 by MadCompie.
Posted by: pspad | Date: 2020-05-25 13:54 | IP: IP Logged
Have you changed file content to influence of filesize? Cause as I remember, I can ask fize of FTP objekt, but not the datetime.
Posted by: MadCompie | Date: 2020-05-25 14:17 | IP: IP Logged
I did not change anything through FTP...
Just opened the file and then using PSPad VBscript I open the temp file.
After the external modification of the temp file, PSPad did not detect the change anymore...
Posted by: Extranjero | Date: 2020-05-25 22:00 | IP: IP Logged
--> Skins - Program settings / Colors - is possible to change program skin to black
Works like a charm!
Thank u!
Posted by: bruste | Date: 2020-05-26 06:09 | IP: IP Logged
I'm not able to use dark theme. When I select "pspad dark" skin, in color config menu, and I press apply it becomes black but as soon I press ok it reverts to white.
Any idea ? I tried to delete all my config files from AppData\Roaming\PSpad and start with a clean config, but I've got the same issue.
Posted by: pspad | Date: 2020-05-26 06:17 | IP: IP Logged
Where is PSpad installed? Did you installed full version of PSPad?
If you installed PSpad and is placed in Program files folder, do you have
Program settings / System integration - multiuser environment enabled?
Posted by: bruste | Date: 2020-05-26 06:27 | IP: IP Logged
pspad:Where is PSpad installed? Did you installed full version of PSPad?If you installed PSpad and is placed in Program files folder, do you have
Sorry, it works. I don't know why, when I press ok it reverts to white, but if I close and reopen pspad it is black.
Thanks
Posted by: naputtelija | Date: 2020-05-27 04:49 | IP: IP Logged
Two problems with 407:
- Program saves top and left coordinates on close but does not use them when launching. Tested on three different PCs
- HTML export to clipboard still uses white background when dark theme is selected
Posted by: pspad | Date: 2020-05-27 06:41 | IP: IP Logged
naputtelija:Two problems with 407:- Program saves top and left coordinates on close but does not use them when launching. Tested on three different PCs
hello
I can't confirm the first problem.
Posted by: MadCompie | Date: 2020-05-27 06:46 | IP: IP Logged
pspad:Have you changed file content to influence of filesize? Cause as I remember, I can ask fize of FTP objekt, but not the datetime.
Hi Jan,
Small update on my problem : it was probibly a coincidence...
Good news : the file change detection using FTP files still works with the new version! And the issue has nothing to do with FTP...
When I change a text "ABC" into "012345", PSPad does detect a file change = OK.
But probably what I encountered (and confused me) was changing a text "ABC" into "XYZ" : the contents are indeed different but the SIZE remain the same, so : no file change...
Perhaps that could be a solution : maintaining some kind of a hash of the file?
