You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2658) English
Posted by: pspad | Date: 2015-04-12 16:28 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2657)
News
User highlighter - possibility to define own escape char
Code explorer for Autohotkey - class support added
Code explorer - C++ code without functions
File with R/O attribute doesn't set R/O status
horizontal line behind the last char with some fonts
Code explorer for Autohotkey - wrong listed function call inside function and some other small fixes
Posted by: ok1 | Date: 2015-04-13 23:49 | IP: IP Logged
The change for "horizontal line behind the last char with some fonts" has fixed an odd display issue I had with the last character.
Wasn't a big issue but thanks anyway.
Posted by: pash | Date: 2015-04-17 09:54 | IP: IP Logged
Got this a second time, switchting between rdp sessions.
Problem signature:
Problem Event Name: APPCRASH
Application Name: PSPad.exe
Application Version: 4.6.0.2658
Application Timestamp: 552ab77f
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.18409
Fault Module Timestamp: 53159a86
Exception Code: 0eedfade
Exception Offset: 0000c42d
OS Version: 6.1.7601.2.1.0.16.7
Locale ID: 1031
Additional Information 1: 1fa4
Additional Information 2: 1fa4a05fd44739772bf879bc527a55c5
Additional Information 3: 483f
Additional Information 4: 483ff873a545244a5d945bd030e4d673
Exception EOSError in module PSPAD.exe at 00011EE6
System Error. Code: 5.
Access is denied.
Didn't happen in pspad460b2656. So I'm going back to that version and test.
Edited 1 time(s). Last edit at 2015-04-17 09:59 by pash.
Posted by: padfox | Date: 2015-04-19 23:08 | IP: IP Logged
Hello again,
hotkeys ([Alt+_] combinations) aren't shown in the main menu, but for the menu items.
Many thanks and greetings
padFox
Posted by: padfox | Date: 2015-04-19 23:58 | IP: IP Logged
Concerning: hotkeys ([Alt+_] combinations)...
yep, the problem is again the Deutsch.ini file. The '&' are missing.
Jan, I will send you that corrected file tomorrow.
padFox
Posted by: pash | Date: 2015-04-29 08:14 | IP: IP Logged
Mhh... 4.6.0.2656 also crashes sometimes by switching between windows of other apps.
Problem signature:
Application Version: 4.6.0.2656
Application Timestamp: 5517f5e9
Locale ID: 1031
Additional Information 3: 123d
Additional Information 4: 123d1d3363fa1d758a5a15b146036ee3
