You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2401) English
Posted by: pspad | Date: 2010-12-07 22:09 | IP: IP Logged
Download links (1.8 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.5 (2395)
News
Autocomplete appears automatically. You can set delay in Program settings / Editor2
Log parser extended capabilities (Highlighter settings / Compiler)
Added -i /i switch what allows you use alternative config file for PSPad
Load file using plugin autodetects UTF-8 encoding
User highlighter - new multiline comment style * … ;
Program settings / System - new option allows you minimize program instead close it
LOG parser debuger
Posted by: carbonize | Date: 2010-12-08 09:05 | IP: IP Logged
Cincura.net download isn't working. Getting 404.
Carbonize
Posted by: pspad | Date: 2010-12-08 09:38 | IP: IP Logged
I know. Now it would be ok.
Posted by: Manfred62 | Date: 2010-12-08 10:11 | IP: IP Logged
In settings/ system integration:
there's no translation for
Editor pro Total Commander?
Is it possible to get tooltip function for settings/editor 2Group UNDO
triedcGroupUndo_Hint=Group UNDO (bla bla..)
doesn't run?
regards Manfred
PSPad 4.5.9 (2525)
Posted by: pspad | Date: 2010-12-08 11:38 | IP: IP Logged
Editor for Total commander and IE was removed.
I forgot to remove it from localization.
I will add hint possibility for Group UNDO
Posted by: stefangabos | Date: 2010-12-08 11:41 | IP: IP Logged
can i disable the "autocomplete" auto-pop-up? it keeps appearing over ALL my windows, whether I am in PSPad or not...I've tried putting a huge delay (like 99999) but the maximum is of 10 seconds.
Posted by: pspad | Date: 2010-12-08 12:09 | IP: IP Logged
Of course you can disable it. Set delay interval to 0
Posted by: clanman | Date: 2010-12-08 12:46 | IP: IP Logged
Very nice update.
Call me blind however what exactly are the log parser extended capabilities.
I was hoping to see the corrections to to the internal vbscript I sent through. Is there any indication when this might be amended?
I love the automatic auto complete - fantastic!
Posted by: stefangabos | Date: 2010-12-08 13:35 | IP: IP Logged
great! thanks!
Posted by: pspad | Date: 2010-12-08 15:17 | IP: IP Logged
clanman:Very nice update.Call me blind however what exactly are the log parser extended capabilities.
Go to Highlighter settings / Compuler / Debug button
There are new variables like Drive what can be used.
As I remember, somebody sent me log, where was two paths.
It's easy not to filter it: %D%F e.t.c.
