You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2386) English
Posted by: mgutt | Date: 2010-04-24 20:28 | IP: IP Logged
sorry, pspad supports it. i've overlooked the function.
invisible = hidden
Posted by: kenquad | Date: 2010-04-28 16:20 | IP: IP Logged
Hi, I have some dialogs stuck in the Czech language - particularly the "Synchronize With Disk" command under the Projects menu item and the "File was modified externally" popup message. This isn't a big deal; just thought it should be added to this thread.
Posted by: se7h | Date: 2010-04-29 11:38 | IP: IP Logged
One of items is in Czech language, regardless of chosen language
added:
need add string to all langfiles "aFileTabSort_Caption="
Edited 1 time(s). Last edit at 2010-04-29 11:50 by se7h.
Posted by: JanoSk | Date: 2010-04-30 05:30 | IP: IP Logged
Hello se7h,
Thursday, April 29, 2010, 11:38:23 AM, you wrote:
s> (viz img15.imageshack.us )
s> One of items is in Czech language, regardless of chosen language
When I switch my PSPad to russian translation, then this item is appear on
english, not on czech...
In slovak translation this item is appear OK.
It is because russinan.ini not completely translated?.
On discussed language files on PSPad I have this:
Slovak.ini:
aFileTabSort_Caption=Zoradiť záložky abecedne
Russian.ini:
;;Translate
aFileTabSort_Caption=Sort file tabs alphabetically
Best regards,
Jano
Posted by: se7h | Date: 2010-04-30 10:36 | IP: IP Logged
Sorry, apparently I have an obsolete file
Posted by: kenquad | Date: 2010-05-05 01:45 | IP: IP Logged
Not sure if this is a bug or a feature, but "synchronize with disk" is grayed out unless at least one file of a project is open.
Posted by: pspad | Date: 2010-05-05 08:17 | IP: IP Logged
kenquad:Not sure if this is a bug or a feature, but "synchronize with disk" is grayed out unless at least one file of a project is open.
I will check it. From your description it looks like a bug
Posted by: elxDraco | Date: 2010-05-09 17:48 | IP: IP Logged
I get this error when I try to open a file on my FTP, never had problems with it before. Sadly I can't test it with another FTP.
It gives me this error under the title "Unable to create directory.":
Exception class:
Exception address:
Stack list, generated 5/9/2010 5:44:36 PM
No dumps into the forum please. Send them to the author via email address found under the help menu.
---------------------------------------------------------------------------------------------------- Program : C:\dev\PSPad\PSPad.exe 4.5.5 (2386) System : Windows 7 Home Edition, Version: 6.1, Build: 1DB0, "" Processor: Intel, Genuine Intel(R) CPU U7300 @ 1.30GHz, 1733 MHz MMX Display : 1366x768 pixels, 32 bpp ---------------------------------------------------------------------------------------------------- Active Controls Hierarchy: TListView "" TfFTP "" TTabSheet "" TPageControl "" TPanel "" TfPSPad "" ----------------------------------------------------------------------------------------------------
Edited 1 time(s). Last edit at 2010-05-13 12:47 by Stefan.
Posted by: papi | Date: 2010-05-17 14:54 | IP: IP Logged
I found something annoying: if i have several opened files in the editor, and open another one (for example from total commander), it looks like, that the editor opens again every files; it flashes and run through on all opened files.
Now I went back to build 2356, because i did not see this issue there. Otherwise the configuration is the same in both cases.
Sorry if somebody already reported this, i had no time to check every comments before.
Thank you!
Posted by: Thralia | Date: 2010-05-17 14:58 | IP: IP Logged
I can confirm this behavior.
