You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2386) English
#11 Re: %File% bug
Posted by: vbr | Date: 2010-03-24 22:27 | IP: IP Logged
ferry:
"In the favorite panel, you can set any count of compilers you need."
I cannot find this panel. Not in "Project settings", nor in "Highlighter settings".
Where is it, please?
View: Tool panel (Ctrl + F2)
(tab with the heart icon in some icon sets)
#12 Re: %File% bug
Posted by: pspad | Date: 2010-03-25 05:51 | IP: IP Logged
ferry:
On the left side is project panel. There is tab with hearth symbol. Use Tool folder
#13 Re: PSPad unicode 4.5.5 (2386) English
Posted by: karminski | Date: 2010-04-02 07:22 | IP: IP Logged
Quote:
This may be a more extension-specific issue, but this build seems to have broken (at least) the any_tag_close extension.
Instead of placing the close tag at the cursor, it's placed at the beginning of the line. Possibly the cursor position isn't being properly read.
In this case, you can get the extension working again by uncommenting line 105, although the page then scrolls, which might be why this line was commented out.
Seems problem is not solved in this build. Please fix it!
1C-Bitrix: web-site logic and interface developer
#14 Re: PSPad unicode 4.5.5 (2386) English
Posted by: Lolo | Date: 2010-04-02 10:25 | IP: IP Logged
I have found a bug (I think) in version 4.5.5 build 2386.
Here is the way to reproduce it:
- Open PSPad and active Line Wrapping
- Open file1.txt with notepad and paste its content into PSPad
- Create a new empty file, open file2.txt with notepad and paste its content into PSPad => PSPad show error dialog
Or you can simply reproduce it by pasting the content of file2.txt four times and undo all.
Can you reproduce it?
You can find all useful files here (error.log file included):
rapidshare.com
Thanks and have a nice day.
#15 Re: PSPad unicode 4.5.5 (2386) English
Posted by: karminski | Date: 2010-04-02 12:05 | IP: IP Logged
Lolo:
Hey, Lolo,
I have same bug issue with Word Wrap enabled. But for me this bug gets from "stable" 4.5.4 release. Its occured when i'm using unicode characters in my code (mostly russian)
But no fix yet!
Edited 1 time(s). Last edit at 2010-04-02 12:06 by karminski.
#16 Re: PSPad unicode 4.5.5 (2386) English
Posted by: BloodSword | Date: 2010-04-02 13:01 | IP: IP Logged
Smarty {} highlighting (orange) is missing in the (X)HTML Multi-Highlighter. :( Reverted to older version.
#17 Re: PSPad unicode 4.5.5 (2386) English
Posted by: pspad | Date: 2010-04-02 13:24 | IP: IP Logged
BloodSword:
In highlighter settings / HTML on the second tab allow template highlight - see changelog
#18 Re: PSPad unicode 4.5.5 (2386) English
Posted by: BloodSword | Date: 2010-04-03 20:09 | IP: IP Logged
Thank you. Is there a way to higlight the syntax of smarty inside the {} brackets?
#19 Re: PSPad unicode 4.5.5 (2386) English
Posted by: Laisvunas | Date: 2010-04-04 15:08 | IP: IP Logged
In 4.5.5 (2386) on the bottom of the file a lot of white space is displayed even in cases file is long. That is the same issue as was present in build 2383, but diappeared in later builds. See the image.
#20 Re: PSPad unicode 4.5.5 (2386) English
Posted by: pspad | Date: 2010-04-04 16:22 | IP: IP Logged
Program settings / Editor
there is allowed access to behind EOL and EOF
