You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2335) English
#21 Re: PSPad unicode 4.5.4 (2335) English
Posted by: pspad | Date: 2008-11-27 10:10 | IP: IP Logged
hulmgulm:
I have a problem with the FTP client in 4.5.4 compared to 4.5.3:
Our FTP server has a lot of symbolic links to directories. In 4.5.3 the FTP client showed them as folders and I was able to open then as a folder.
4.5.4 shows them only as files and I cannot open them anymore.
Is this a bug or a feature?
Thanks for your great application!!!!
Connect to your FTP server, navigate to folder with symlinks, show FTP LOG (Ctrl+L), press LIST button (on the left side in LOG) and send me result via mail as attachment
#22 Re: PSPad unicode 4.5.4 (2335) English
Posted by: hulmgulm | Date: 2008-11-27 12:14 | IP: IP Logged
You got mail
#23 Re: PSPad unicode 4.5.4 (2335) German
Posted by: Hanno | Date: 2008-12-01 09:11 | IP: IP Logged
If I use the toolbox button "Create new file" and choose XHTML then I get a regular HTML document.
If I use
"File -> New -> Use Template -> XHTML -> XHTML 1.0 Strict utf-8"
then I get the right document but it contains "<head><!-- ščřžýŠČŘŽÝ -->".
Thank you and regards,
Hanno
#24 Re: PSPad unicode 4.5.4 (2335) German
Posted by: pspad | Date: 2008-12-02 06:39 | IP: IP Logged
Hanno:
If I use
Modify .\Template\Default.html file
New file is created from file default.[extenison]
#25 Re: PSPad unicode 4.5.4 (2335) German
Posted by: Hanno | Date: 2008-12-03 08:02 | IP: IP Logged
Thank you for your fast reply
BUT
- the "default.xhtml" is different from "default.html"
- creating a new xhtml file is using the "default.html"
Hanno
#26 Re: PSPad unicode 4.5.4 (2335) German
Posted by: pspad | Date: 2008-12-03 08:15 | IP: IP Logged
As I wrote, PSPad creates new file for extension.
If you want to have different content fr .HTML, you need to modify default.html file
#27 Re: PSPad unicode 4.5.4 (2335) German
Posted by: Hanno | Date: 2008-12-04 09:31 | IP: IP Logged
Oh, I think there is misunderstanding.
I have different default templates (for *.html and *.xhtml).
My problem is:
If I create a new file with the toolbar icon "Create new file" with
1. HTML
2. XHTML
then I get the same (!) result - "newX.html".
Hanno
Edited 1 time(s). Last edit at 2008-12-04 09:31 by Hanno.
#28 Re: PSPad unicode 4.5.4 (2335) German
Posted by: pspad | Date: 2008-12-04 11:37 | IP: IP Logged
Again
PSPad takes .<extension> if you create new file.
You create something.html, pspad takes default.html
If you will create something.xhtml, PSPad will take default.xhtml
File name is irelevant in this case
#29 Re: PSPad unicode 4.5.4 (2335) German
Posted by: Hanno | Date: 2008-12-04 14:50 | IP: IP Logged
Sorry but this is the problem - PSPad should take default.xhtml but it takes default.html.
Hanno
#30 Re: PSPad unicode 4.5.4 (2335) German
Posted by: pspad | Date: 2008-12-04 15:35 | IP: IP Logged
This is nonsence discussion.
I explained you PSPad behaviour.
If you want to have different default template for something.HTML, open default.HTML and modify it.
PSPad offers you this possibility, use it.
