You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2335) English
Posted by: arek1 | Date: 2008-11-25 12:02 | IP: IP Logged
Problem with wordwrap lines longer then 1500-1700 characters still exist :(
I send Error log by email.
Even turning off 'Wrap (Soft) with Right Edge' in settings is not complete solution. It just giving possibility editing lines about 2000 characters. Longer lines create exeption even with this setting turned off.
This error is so confusing me, Word Wrap is one of common used function. Is it important only for me?
Best wishes
ArekS
Posted by: zeeric | Date: 2008-11-25 14:38 | IP: IP Logged
hello
is it possible in pspad to add words for an existing langage ? for instance, add a reserved word to java or els? thanks
Posted by: MrSpock | Date: 2008-11-25 18:52 | IP: IP Logged
zeeric:is it possible in pspad to add words for an existing langage ? for instance, add a reserved word to java or els? thanks
For the built-in languages, this isn't possible. But you can make a user highlighter for Java.
Posted by: pspad | Date: 2008-11-25 20:10 | IP: IP Logged
muthukrish_2000:Is there any feautre in PSPAD to select different Lines at a single shot, like in Microsoft word.
Ex: I can select by holding CTRL Key and then selecting 1st Line, 3rd Line,etc..![]()
No, because there is no reason for it.
Posted by: pspad | Date: 2008-11-25 20:34 | IP: IP Logged
zeeric:hellois it possible in pspad to add words for an existing langage ? for instance, add a reserved word to java or els? thanks
If you need to add words into built-in highighters and this keywoards are missing, write me list of keywords
Posted by: Bobf | Date: 2008-11-26 07:18 | IP: IP Logged
Hello Jan,
i have the same problem in german.
When you set interface language to "German" and click on the "File" menu, you'll notice "Nový..." instead of "New...".
I download today 25th Nov. the buid 2335 again, but it's still the same.
rgs Bob
Posted by: Bobf | Date: 2008-11-26 07:30 | IP: IP Logged
Hi ArekS,
i have the same problem, and it's important for me too.
When i past text with more than 1700 characters into PsPad and Word Wrap is on, PsPad crashes with an exception, and the exception runs into a loop. In this case i must kill the pspad process.
In build 2331 i got the exception too, but there i could acknowldge the exception and could still work with PsPad.
So i think this should be fixed.
rgs Bob
Posted by: zeeric | Date: 2008-11-26 08:00 | IP: IP Logged
thanks for the answer
well it would be a good thing to be able to add keywords for existing langages.
I often add to editors keywords like string, map (C++), or JPanel, JFrame (java). They are not really keywords, but it's a good thing to be able to add them.
I don't understand why pspad don't give access to the list of words like the others editors...
as a second little probleme is the spell checker.
when you ask to underline bad words, if you use word wrap and scroll, underline disappear often.
anyway, thanks for this master piece of work
Posted by: pspad | Date: 2008-11-26 08:04 | IP: IP Logged
It's very easy to create user highlighter, switch off built-in highlighter and use your own one
Posted by: hulmgulm | Date: 2008-11-27 07:41 | IP: IP Logged
I have a problem with the FTP client in 4.5.4 compared to 4.5.3:
Our FTP server has a lot of symbolic links to directories. In 4.5.3 the FTP client showed them as folders and I was able to open then as a folder.
4.5.4 shows them only as files and I cannot open them anymore.
Is this a bug or a feature?
Thanks for your great application!!!!
