You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2275) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 4.5.3 (2275) English
Posted by: menet | Date: 2007-09-20 21:00 | IP: IP Logged
Thank to Jan, smiling smiley
This version 2275 seems to correct well my problem with my script that reduce PSPAD in the tray bar when I close a file with it. smoking smiley
Best regards winking smiley
#12 Re: PSPad unicode 4.5.3 (2275) English
Posted by: PGomersall | Date: 2007-09-20 21:37 | IP: IP Logged
Jan,
We have started to get an error dialog from the context menu (cascaded) when Users running as a normal user (not administrator) try to open a file with PSPad (any choice on the context menu).
This says "Error executing PSPad editor". Everything works fine as an Admin user though. The fix that is mentioned in other forums - Open PSPad settings and click OK does not fix this. Can you help me find what is causing this or do you know already?
This has been happening for many of the beta releases since last full release - it is not a new issue. I just haven't had time to report it.
Thanks,
Pete Gomersall
Edited 1 time(s). Last edit at 2007-09-20 22:08 by PGomersall.
#13 Re: PSPad unicode 4.5.3 (2275) English
Posted by: mahira | Date: 2007-09-21 05:54 | IP: IP Logged
A quick release will be appreciated winking smiley
Thanks...
I know and already it is corrected. I will release update.
#14 Re: PSPad unicode 4.5.3 (2275) English
Posted by: jeroenvb | Date: 2007-09-21 09:42 | IP: IP Logged
I noticed the "wrap search without asking"-bug is fixed. Thanks very much!
#15 Re: PSPad unicode 4.5.3 (2275) English
Posted by: MoMann | Date: 2007-09-21 14:36 | IP: IP Logged
Thank you for the "body" lookup in code exploer. It's a BIG help!!!
-MoMann
#16 Re: PSPad unicode 4.5.3 (2275) English
Posted by: hankejh | Date: 2007-09-22 15:46 | IP: IP Logged
Thanks for the update, Jan!
I have noticed one odd behavior that I do not recall experiencing with previous builds. When I use [Window > Horizontal Split], I adjust the position of the horizontal split bar to a desire location. When I switch to another tab, then back to the tab with Horizontal Split - the location of the split is repositioned in the middle - rather than retaining the position I set it to.
#17 Re: PSPad unicode 4.5.3 (2275) English
Posted by: pspad | Date: 2007-09-23 12:00 | IP: IP Logged
hankejh:
OK
#18 Re: PSPad unicode 4.5.3 (2275) English
Posted by: pspad | Date: 2007-09-23 12:27 | IP: IP Logged
To Tab switch.
I will change option to combo box with items:
standard behavior - smart switch is off
last two files - switch last two files only
last used order - previous behavior
