You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2241) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.2 (2241) English
Posted by: pspad | Date: 2006-10-31 21:05 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.2 (2240)
Corrections
send file as mail attachment works for modified file only
Code explorer for C++ - quoted code problem
font editor change has no influence of the ruller
corrected ruller position of the right edge
Ctrl+Tab behaviour
Cobol Code explorer
unsucessfull HEX editor save without warning message
#2 Re: PSPad unicode 4.5.2 (2241) English
Posted by: Eblis | Date: 2006-10-31 21:27 | IP: IP Logged
Sorry to be a nag but there are still some bugs that haven't been fixed.
Selection bug (#10), new line bug (#12), and a feature request.
Can you please post if you know about them but they can't/won't be fixed for any reason ? Or if you're working on a fix now but it's not yet ready. So I know you've acknowledged them and i don't repost them smiling smiley
Edited 1 time(s). Last edit at 2006-10-31 21:41 by Eblis.
#3 Re: PSPad unicode 4.5.2 (2241) English
Posted by: Jeroen | Date: 2006-10-31 21:56 | IP: IP Logged
Thanks Jan!
Eblis:
Same for forum.pspad.com, please let me know if you're working on it.
#4 Re: PSPad unicode 4.5.2 (2241) English
Posted by: pspad | Date: 2006-10-31 22:05 | IP: IP Logged
Eblis:
I got all messages from PSPad forum to my mailbox.
I am not able to answer to all.
I am not able to make all request in realtime.
Your CrLf problem - program settings / Editor-behaviour
[]Add CRLf to EOF
Other your problem are not bugs. PSPad uses component with same behaviour as Delphi IDE.
#5 Re: PSPad unicode 4.5.2 (2241) English
Posted by: Nelson | Date: 2006-11-01 02:25 | IP: IP Logged
Sorry, but this bug still exists. sad smiley
Could you please try to fix it?
#6 Re: PSPad unicode 4.5.2 (2241) English
Posted by: MrSpock | Date: 2006-11-01 03:11 | IP: IP Logged
Corrections
I thought this should fix the ruler problems, but this doesn't seem to be the case. The following screenshot was taken with build 2241:
#7 Re: PSPad unicode 4.5.2 (2241) English
Posted by: pspad | Date: 2006-11-01 05:42 | IP: IP Logged
MrSpock:
Thank you. There was a problem that if you zoom font size with mouse, the Gutter font stays asi it. It will be fixed in new build.
#8 Re: PSPad unicode 4.5.2 (2241) English
Posted by: pspad | Date: 2006-11-01 06:39 | IP: IP Logged
Nelson:
Today is a good day. I found a problem and fix it winking smiley
#9 Re: PSPad unicode 4.5.2 (2241) English
Posted by: Eblis | Date: 2006-11-01 09:37 | IP: IP Logged
[]Add CRLf to EOF
The same thing happens even if Add CR + LF to EOF is unchecked in options. So pspad adds a newline even if that setting is unchecked.
It's been a while since i used Delphi and i don't remember how selection behaved in it; could you please change PsPad so it only selects words? In the example i gave before:
SetAppUser App, "Domain", "|User", TRUE, TRUE --- (| denotes the current cursor position)
i would like pspad to select only Domain when pressing Ctrl + Shift + Right:
SetAppUser App, "Domain|", "User", TRUE, TRUE --- (| denotes the current cursor position)
I'm sorry if i'm the only one that expects Selection to work that way, if that's the case just ignore my request.
And thanks for a awsome editor and for replying ... keep up the great work.
#10 Re: PSPad unicode 4.5.2 (2241) English
Posted by: Jon | Date: 2006-11-01 10:54 | IP: IP Logged
Okay, I give up.
It is now for four versions (2238..2241) that the Next/Previous Window bug is in PSPad. The "Next Window" entry is also still not back in the Window menu.
This bug means that I can't use PSPad (without changing the habits of a lifetimesad smiley ). A pity but so be it. Or perhaps I go back to the last version without that bug.
