You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2240) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.2 (2240) English
Posted by: Jon | Date: 2006-10-21 09:17 | IP: IP Logged
Jan,
thx for the new release. Alas, the bug with Next/Previous Window I first reported for 2238 is still around. And not only that... "Next Window" is now gone from the Window menu altogether. The keyboard shortcuts I defined still work so for me the latter is a cosmetic problem.
Is this thing really so difficult to fix?
#12 Re: PSPad unicode 4.5.2 (2240) English
Posted by: Eblis | Date: 2006-10-23 12:12 | IP: IP Logged
Bug:
PsPad always adds CR+LF to the last line of a file, even if the file doesn't contain that character. (happens regardless if "Add Cr+Lf to EOF" is checked or not)
The hex editor works, it shows the file without the second carriage return but the normal text editor doesn't work correctly, it shows a second carriage return which doesn't exist.
#13 Re: PSPad unicode 4.5.2 (2240) English
Posted by: Eblis | Date: 2006-10-24 06:29 | IP: IP Logged
I would also like to point out this feature request smiling smiley
#14 Re: PSPad unicode 4.5.2 (2240) English
Posted by: pspad | Date: 2006-10-24 16:10 | IP: IP Logged
wal:
Hi Jan,
Thank you for the new release.
Unfortunatelly, it has new bug in C/C++ code explorer which seems wasn't in the build 2239. Now code explorer analyzes comment blocks and add functions to code explorer. Here is example of comment block in C:
It is just comment ( C/C++)
In code explorer appears:
comment ( C/C++)
Regards,
Wal
OK. Correction will be available in the next build
#15 Re: PSPad unicode 4.5.2 (2240) English
Posted by: Jura | Date: 2006-10-24 19:55 | IP: IP Logged
Thanks for this new version.
Please fix search speed. It is very sloooow (at least 20 times slower than in old versions). I need to turn on regexp search always because it is fast.
#16 Re: PSPad unicode 4.5.2 (2240) English
Posted by: timyau18 | Date: 2006-10-25 03:29 | IP: IP Logged
This version is still slow when open a file...
My c++ file is just 268kb, but it needs about 5 seconds to open.
Is there anything I can do to make it open file quickly?
I have checked off many system settings....sad smiley
#17 Re: PSPad unicode 4.5.2 (2240) English
Posted by: pspad | Date: 2006-10-25 04:28 | IP: IP Logged
timyau18:
Problem is in he Code explorer. If you want to parse 260kB long file, it takes a time.
#18 Re: PSPad unicode 4.5.2 (2240) English
Posted by: molinarm | Date: 2006-10-25 08:53 | IP: IP Logged
Jan,
will this be available as an update of the official release, or just as a new beta? I think it would be worth an official release, as it is much of an annoyance if you use PSPad to write C/C++ code.
Cheers,
Mario Molinari
#19 Re: PSPad unicode 4.5.2 (2240) English
Posted by: pspad | Date: 2006-10-25 10:23 | IP: IP Logged
I will wait for some new problems some time and then I will update latest release and publish new beta with same functionality.
#20 Code-Explorer and CSS
Posted by: phoenix | Date: 2006-10-25 11:05 | IP: IP Logged
thx for the update - a great editor. smiling smiley
One thing I found out in the codeexplorer. If you write your css-code like this:
#example1,
#example2,
#example3
the codeexpl. will show you:
- #example3 (...nothing more)
If you write it like this:
#example1, #example2, #example3
all ID's are visible in the codeexpl.
Bug or Feature?
phoenix0107
