You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2237) English
Posted by: Eblis | Date: 2006-09-05 09:16 | IP: IP Logged
Could you change the confirm exit text to something like "Are you sure you want to close PsPad" ?
And a feature request:
Currently if you close PsPad and there are files that haven't been saved it asks you if you want to save the files but after that it also asks you if you want to confirm exit. Could this be changed so if you get the messagebox asking if you want to save changes the confirm exit dialog is not shown anymore ? You can use the Cancel button of the confirm save dialog if you want to keep pspad running ...
Posted by: snija | Date: 2006-09-05 12:16 | IP: IP Logged
Please take a look at this.
I`ve set the log entry with string begins with variable(%).
But after i press add, things in log entry are lost.
It seems that the program turn the separator ( character with hex code A7 ) and % into another character and cause the program malfunction.
Thank you.
Edited 1 time(s). Last edit at 2006-09-05 12:17 by snija.
Posted by: Brico Pierre | Date: 2006-09-05 13:22 | IP: IP Logged
Hi Jan,
Thanks for the C/C++ highlighter bug fix. I just want to know why you have change the behaviours. Until build 2234, the entire line with precompiler code was highlightered in the same color (and this is right). For now, only the precompiler keywords (like #include) are highlightered.
Old way (2234):
New way (2237):
Thanks you in advanced,
Pierre
Posted by: Wackx | Date: 2006-09-05 13:27 | IP: IP Logged
Brico Pierre:Hi Jan,Thanks for the C/C++ highlighter bug fix. I just want to know why you have change the behaviours. Until build 2234, the entire line with precompiler code was highlightered in the same color (and this is right). For now, only the precompiler keywords (like #include) are highlightered.
Old way (2234):
New way (2237):
Pierre
Pleas make this optional. Thx!
Posted by: Stefan | Date: 2006-09-05 17:53 | IP: IP Logged
Jan Fiala, thank you for this new build and all your work!
Posted by: steph | Date: 2006-09-06 17:17 | IP: IP Logged
Hi Jan,
It seems that the trouble with log window is solved (all characters of a same line were written at the same place see forum.pspad.com)
Did you change anything?
Thx.
Posted by: gogogadgetscott | Date: 2006-09-07 01:25 | IP: IP Logged
Latest build displays special characters differently then past versions. Please restore older display. I prefer the display in green circle over the new display in red circle.
Posted by: Markus Kiendl | Date: 2006-09-07 07:58 | IP: IP Logged
gogogadgetscott:Latest build displays special characters differently then past versions. Please restore older display. I prefer the display in green circle over the new display in red circle.
Hi gogogadgetscott,
could it be that you have used different fonts for the two screenshots? The one with the correct display uses Courier, but the one with the incorrect display definitly doesn't. Maybe this is a problem with the font you are using.
Markus
Posted by: gogogadgetscott | Date: 2006-09-07 23:41 | IP: IP Logged
Markus Kiendl:Maybe this is a problem with the font you are using.
Thanks, Markus.
Posted by: Stefan | Date: 2006-09-09 09:10 | IP: IP Logged
Posted by: steph | Date: 09/07/2006 09:48 | IP: 80.156.46.51
in an separate thread ... iam only join this two threads here now:
steph:Hi Jan,It seems that the trouble with log window is solved (all characters of a same line were written at the same place see forum.pspad.com)
Thx.
I was wrong : this problem came back today and I couldn't find why.
I have to retreive b2217.
