You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2234) English
Posted by: pspad | Date: 2006-08-27 21:29 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.2 (2231)
News
scripting support - new general functions:
ftpConnect(connection: string): Boolean - connect to defined FTP connection
ftpDisconnect - disconnect FTP server
ftpCommand(příkaz: string) - send command to FTP server, e.g.. "CWD \public\www"
ftpDownloadFile(ftp_name, local_name): Boolean - download any file from FTP
ftpUploadFile(local_name, ftp_name): Boolean - upload any file to FTP
scripting support - new editor functions:
readOnly(status: Boolean): Boolean - set or return current editor R/O status
openFileFromFTP(name): Boolean - open file from FTP
saveFileToFTP: Boolean - save open file to current FTP directory
FTP connection window is resizable
column block mode sets automatically scroll past EOL
new clor option for the left gutter font color
Corrections
macro record doesn't allow to recod unicode chars. Macro files are from now stored in unicode and are not compatible with older PSPad version!
SQL code explorer and '$' char in procedure name
NO answer in confirm dialog after closing modified project file
User highlighter definition - wasn't possible to enter '_' and '-' cars in file filters
Color select / Namd colors - problem with names for 'cyan', 'magenta'
Project panel and rename folder using context menu
Save file state and bookmarks
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
Posted by: MrSpock | Date: 2006-08-28 01:09 | IP: IP Logged
Again, many thanks for the new build.
I've noticed two small glitches concerning the Settings dialog (lowest priority): (1) The new button for the gutter font color looks like it's one or two pixels too high. At least on my display, its top is hidden by the button above it. (2) I think the text for the cursor hint for the same thing is missing in the language files. I have a Czech cursor hint, but couldn't find the string in the ini file.
I really like the new <Alt>-Select behavior. Very intuitive!
Posted by: Nelson | Date: 2006-08-28 01:42 | IP: IP Logged
Great job!
Hope the "CSS brace highlighting" bug can be fixed in the future build.
Posted by: Michael Wangler | Date: 2006-08-28 05:46 | IP: IP Logged
From the version 4.5.2 Build 2231 on , i have the following behaviour in the log window:
could you please fix this?!
Best regards
Michael Wangler
Posted by: pspad | Date: 2006-08-28 05:54 | IP: IP Logged
For me is hard to fix it because I don't have this problem
I will check changes made in the 2231 to find reason of this problem
Posted by: Eblis | Date: 2006-08-28 06:37 | IP: IP Logged
The confirm exit text is still not in English (someone reported this for the previuos build); it reads "Opavdu ukonèit PSPad editor ?"
I'm using Consolas as my Font and i have set a greenish color for "Space". But as you can see in the screenshot space characters are white and only tab characters are greenish. Is that supposed to happen ? Also, i'm getting question marks instead of the "normal" characters for whitespace. Is there any place (setting) where i could set what characters to use for whitespace (space, tab and new line) ?
Posted by: Lolo | Date: 2006-08-28 09:14 | IP: IP Logged
Hello Jan,
First of all, thanks a lot for this new release.
This release always have a small bug with bookmark.
Try the following example (Warning: do not add an elmpty line at the and of the file)
Now try to navigate between bookmark with Alt+Down => no problem but with Alt+Up you can only navigate between to two first bookmark.
I hope you could fix this small bug.
Thanks and have a nice day.
Posted by: Jume | Date: 2006-08-28 09:44 | IP: IP Logged
Eblis:The confirm exit text is still not in English (someone reported this for the previuos build); it reads "Opavdu ukonèit PSPad editor ?"I'm using Consolas as my Font and i have set a greenish color for "Space". But as you can see in the screenshot space characters are white and only tab characters are greenish. Is that supposed to happen ? Also, i'm getting question marks instead of the "normal" characters for whitespace. Is there any place (setting) where i could set what characters to use for whitespace (space, tab and new line) ?
yes it happens, its an old known bug, if i dont remember wrong is related to synedit (base component)
Posted by: pspad | Date: 2006-08-28 10:04 | IP: IP Logged
Lolo:Hello Jan,First of all, thanks a lot for this new release.
I can't simulate it
Posted by: pspad | Date: 2006-08-28 10:05 | IP: IP Logged
Program setting / Direct edit
chnge: OldSpecialChars=1
