You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Branko Grbac | Date: 2005-08-12 19:32 | IP: IP Logged
Bug, severity: normal/high
Regarding: Show/hide spaces, tabs and line breaks; State: On
Simptoms: Text around and including numbers and some special characters gets misplaced, corrupted, missing
Repercussion: Attempting to edit such text is not pleasant, at least
Posted by: pspad | Date: 2005-08-12 19:41 | IP: IP Logged
> least
What font do you use ?
Can you send some screenshot ?
Posted by: Branko Grbac | Date: 2005-08-13 19:47 | IP: IP Logged
Yes, of course.
www.hwfanatic.freewebsitehost.net
Notice how the number changed it's position, and only because I turned "Show/hide spaces, tabs and line breaks" on. Positioning the cursor in front of "1" and hitting delete will erase the space that appears (but is not, obviously) after the number. This is confusing when doing some serious editing, and not just this simple example.
If you want to reproduce the problem yourslef, I suggest writting a date; that's the most obvious example I have noticed - numbers will get completely mixed up.
Posted by: Branko Grbac | Date: 2005-08-13 19:48 | IP: IP Logged
Sorry, I forgot to say I'm using Courier New, cyrillic script, but the problem doesn't seem related as I tried to use different fonts.
Posted by: pspad | Date: 2005-08-13 21:08 | IP: IP Logged
I tried it, but no problem occures.
I try it with code from your example, with real tabs, exactly as is it in your example.
Posted by: Branko Grbac | Date: 2005-08-15 12:26 | IP: IP Logged
I just redownloaded the latest beta, installed it in an independant folder and ran it that way (out of the box). The problem persists and it is real; I'm am not trying to pull anybody's leg here...
Posted by: Branko Grbac | Date: 2005-08-15 12:27 | IP: IP Logged
Search and replace does not work well (at all) with unicode.
Posted by: pspad | Date: 2005-08-15 12:58 | IP: IP Logged
Please more detailed description.
What you search, what you replace, what is wrong.
You can send me sample file and description what should I search
Posted by: pspad | Date: 2005-08-15 12:59 | IP: IP Logged
I believe you, but if I can't simulate it, its hard for me to do something with your problem
Posted by: phunkydizco | Date: 2005-08-15 14:41 | IP: IP Logged
Enter and Backspace doesn't work anymore. All other keys seems to work. In other applications Enter and Backspace work, so my keyboard is working correctly.
