You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Branko Grbac | Date: 2005-08-15 15:01 | IP: IP Logged
Of course, I'm sorry.
I want to replace all "dj"-s into "đ"-s in one of my documents. When the process starts, right away I can see he is replacing with "d"-s instead of "đ"-s. Same goes for both searching and replacing, the function strips the special latinic character down to an ordinary one (đ->d, š->s etc.). This is not, or is less the case with cyrillic, for example.
My impression: The search function is not unicode-enabled, but work in some cases even so.
Posted by: Branko Grbac | Date: 2005-08-15 15:15 | IP: IP Logged
Maybe this example will give you an idea? If not, then I simply don't know how to explain...
The text: 2004/06/09 13:03:58
The text with ¶ when I just select it all and c/p here: 2004/06/09 13:03:58
The text with ¶ exactly as I see it on-screen: 13:03:58·2004/06/09
Posted by: pspad | Date: 2005-08-15 15:19 | IP: IP Logged
If you mean standard Find/Replace in document, this function should be work with unicode. I will check it.
Posted by: pspad | Date: 2005-08-15 17:05 | IP: IP Logged
Its realy strange, and I don't know reason in this time
Posted by: tested | Date: 2005-08-16 11:55 | IP: IP Logged
as i can see, works fine, thx, but in the ftp-sidebar, the button to rename a file is labled in Cesky i think, but not english
Posted by: pspad | Date: 2005-08-16 12:19 | IP: IP Logged
> english
On my comp its OK about 2 days already
Posted by: Joe Belmaati | Date: 2005-08-16 14:40 | IP: IP Logged
Mine still says "Prejmenovat" 4.5.0/2120
Sincerely,
Joe Belmaati
Copenhagen Denmark
Posted by: pspad | Date: 2005-08-16 15:18 | IP: IP Logged
I mean version 2120 is older than 2 days. Sorry, my time machine doesn't work
Posted by: Rainer Koschnick | Date: 2005-08-16 19:15 | IP: IP Logged
There seems to be a problem with the DTD syntax highlighter. If it is activated, it shows this:
<!ENTITY % adm-name "dm-name NMTOKEN #IMPLIED">
<!-- adm-name
instead of
<!ENTITY % adm-name "adm-name NMTOKEN #IMPLIED">
<!-- adm-name
The first character from the String in "" is missing. If I turn off Show Syntax, the character is there. They are also there with Show Syntax turned on if I select the whole line (go to line and press shift + cursor down).
Posted by: Rainer Koschnick | Date: 2005-08-16 19:17 | IP: IP Logged
On 2nd inspection it actually looks like this:
instead of
So there's an extra blank before the "%" and the "a" missing.
