You are here: PSPad forum > Translation > Re: Danish by MicCo
Posted by: MicCo | Date: 2011-02-22 09:22 | IP: IP Logged
Hi to all translators
I´m new to this forum, but have been using the PSPad editor for quite some years now, and have been updating the danish.ini, language file, for my owne use. But now I´m thinking about makeing it accesable for all users, including in time, the spell file.
To make sure that I release the right version, as is 4.5.5 (2412), the one I use for now, I need to know if there are any other .INI file that is the most upto-date then the english.ini file ?, as it´s that one I have been using in the past, to make sure that I did the correct update of my danish.ini file.... Please inform me!!
Best regards,
MicCo
(I'm the translator of the Danish language file, if You find any error, please contact me.)
The file can be downloaded @ www.micco.dk
Edited 1 time(s). Last edit at 2017-04-19 11:44 by pspad.
Posted by: pspad | Date: 2011-02-22 09:39 | IP: IP Logged
Use Danish.INI from latest build
Search for ;;Translate comments
Translate strings under this comment and remove comment
Send me back the INI file.
I am updating all localizations files with every new build.
Posted by: MicCo | Date: 2011-02-22 10:18 | IP: IP Logged
Thanks, I´m on it then
Best regards,
MicCo
Posted by: MicCo | Date: 2017-04-19 12:46 | IP: IP Logged
PSPad danish lang-file for ver. 4.6.2 (2750) are sendt to support.
Best regards,
MicCo
Posted by: MicCo | Date: 2017-04-19 15:43 | IP: IP Logged
PSPad danish lang-file for ver. 5 are sendt to support.
Best regards,
MicCo
Posted by: MicCo | Date: 2023-02-03 09:51 | IP: IP Logged
PSPad danish lang-file for ver. 5.0.7 (751) are sendt to support.
Best regards,
MicCo
Posted by: MicCo | Date: 2023-03-24 18:11 | IP: IP Logged
PSPad danish lang-file for ver. 5.0.7 (775) are sendt to support.
Best regards,
MicCo
Posted by: MicCo | Date: 2023-03-24 19:03 | IP: IP Logged
PSPad Danish lang-file for ver. 5.0.7 (779) are sendt to support.
The file can also be downloaded @ www.micco.dk
Link : www.micco.dk
Best regards,
MicCo
