You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-04-01 11:16 | IP: IP Logged
When saving a c source file it happens occasionally that the editor is destroying randomly single lines of the file. This is not reproducable but I've seen it now several times since I've upgraded to the 64 bit version of the latest release. I've never seen this before and I would rank it as a very serious bug because it breaks software builds without having the chance to notice it before. If it happens something like
becomes after saving to a line where the bracket is suddenly leaded with several non ASCII garbage characters which I unfortunately cannot copy and paste here. Hex code of this garbage piece is then
C3BF002020E4AE80D98A00007D
The original hex code of that line was:
20202020202020207D
The coding of the file is ANSI with Linux line ending an it is located in a net share of a Windows server.
Posted by: LouCypher | Date: 2021-04-01 11:42 | IP: IP Logged
This seems to be a duplicate of forum.pspad.com
But as already mentioned I've never seen this before while I'm using PSPad for many years now. Only after upgrading to the latest PSPad release it happens several times a day now.
Posted by: LouCypher | Date: 2021-04-01 12:09 | IP: IP Logged
Just a short observation which might help to track this bug down:
Once the problem occurred in a specific line in an opened file the same line gets destroyed reproducably again every time I save this file even after having repaired the violated line. After closing PSPad and reopen the same file again the problem is gone until it returns after a while randomly during work at the same or another place.
Posted by: pspad | Date: 2021-04-01 13:14 | IP: IP Logged
Can you send me this file wirh some instruction to support mail?
Posted by: LouCypher | Date: 2021-04-01 13:26 | IP: IP Logged
Yes, of course. At least the file where it happened today. But it doesn't happen always with the same file at the same line. Because it contains kind of confidential information I'm going to send an encrypted 7Zip file, the password will be "#PSPadGarbage!".
Posted by: LouCypher | Date: 2021-04-01 14:06 | IP: IP Logged
Hm, I've received an error message that the mail with the encrypted source file couldn't be delivered because it contains a potential security issue. I would be glad to be of any help but I'm afraid that I cannot send the file unencrypted.
Posted by: pspad | Date: 2021-04-01 14:09 | IP: IP Logged
No problem. Support mail goes to my pspad.com mailbox and is automatically resend to my gmail account. I guess GMail wrote it to you, but I got your file into pspad.com mailbox.
