You are here: PSPad forum > Bug report / Hlášení chyb > PSPad destroys occasionally lines of source file
Goto Page: Previous1 2 3 Next
#11 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-11-13 07:49 | IP: IP Logged
Yes, my assumption that it happens during the save process was indeed wrong. By pure chance I've seen this problem again within a file I've opened just for reading. So it happens even without typing just when scrolling through a file. The PSPad version I used when I saw it without saving or editing was 5.0.7 (701).
#12 Re: PSPad destroys occasionally lines of source file
Posted by: HansV | Date: 2021-11-15 09:40 | IP: IP Logged
After opening a file, HTML, some strange characters popped up.
copying the resulting code was partial succesfull.
The characters after the y in the first column did not paste in this text...
It should read : <td></tr> , simply enough....
The HEX from the last <br> forward is
..3C 6272 3E0D 0AFF 003C 2F3F 3F00 0D0A 2020 3C74 643E 3C2F 7464 3E
version PsPAD 5.0.6. (589)
<tr>
<td><a href="./schilderijen/schilderijen_index.html">
<img align="middle" src="sch06.jpg" alt="schilderij 6"></a><br>
ÿ
But until the last update of PsPad , i never had any problems...
Hans.
#13 Re: PSPad destroys occasionally lines of source file
Posted by: pspad | Date: 2021-11-15 10:49 | IP: IP Logged
The current build 5.0.7 (705) should be OK.
Available is in the PSPad developer forum
www.pspad.com
#14 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-11-17 10:55 | IP: IP Logged
It happens also with 5.0.7 (705)!
#15 Re: PSPad destroys occasionally lines of source file
Posted by: pspad | Date: 2021-11-17 11:18 | IP: IP Logged
LouCypher:
How often it occurs?
What PSPad functionality do you use? Highlighters, FTP, ...
I need more details that simple message that it happens.
#16 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-11-17 11:56 | IP: IP Logged
Hello Jan, sorry for the extremly short last post which I've only sent to inform you that this problem isn't gone even with the latest development build. I'm using PSPad with C/C++ sources on local filesystems only. When I started this thread I've sent you already code samples via email where I could reproduce this problem relatively often. I have this problem often enough that it is really annoying several times a week, sometimes every few minutes.
As I've written last weekend I've seen this problem the first time within a file where I didn't type anything nor did I save it. The settings of PSPad are more or less the default settings with the highlighter and code explorer for C/C++ being automatically active. Additionally I've enabled virtual space behind line endings and the automatic removal of whitespace from line endings. That's it.
#17 Re: PSPad destroys occasionally lines of source file
Posted by: pspad | Date: 2021-11-17 12:46 | IP: IP Logged
Do you use 32b or 64b build?
#18 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-11-17 12:56 | IP: IP Logged
Sorry I forgot this information: I'm using the 64b build.
#19 Re: PSPad destroys occasionally lines of source file
Posted by: pspad | Date: 2021-11-17 13:08 | IP: IP Logged
Try please 32b build. Replace your 64b buld with 32b
#20 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-11-17 13:10 | IP: IP Logged
Ok, sure. Do I need a full uninstall and reinstall for this or can I simply replace the binaries?
