You are here: PSPad forum > Bug report / Hlášení chyb > tabsize troubles in secondary split window
Posted by: matosimi | Date: 2016-03-06 20:14 | IP: IP Logged
I'm using my own syntax highlighter which has highlighter-specific tabsize set to 10.
When I use TAB in secondary split window, cursor moves only 2 characters in this window instead of 10 as expected.
Then when I try to type some letters after such TAB, these letters are inserted at correct position, BUT cursor position is incorrect.
...also text selection using mouse or shift+arrows is displayed incorrectly in secondary window.
It would be very nice if this will get fixed.
Posted by: pspad | Date: 2016-03-06 20:37 | IP: IP Logged
Can you confirm your bu in latest PSPad build 4.6.1? I't available in PSPad developer forum. There are some fixes related to real tabs already.
Posted by: matosimi | Date: 2016-03-12 14:37 | IP: IP Logged
pspad:Can you confirm your bu in latest PSPad build 4.6.1? I't available in PSPad developer forum. There are some fixes related to real tabs already.
Just tried new version and it really works good.
THANKS!
Posted by: pspad | Date: 2016-03-12 20:15 | IP: IP Logged
matosimi:Just tried new version and it really works good.THANKS!
Thank you for confirmation
