You are here: PSPad forum > Bug report / Hlášení chyb > Re: Line replaced by gibberish characters / Nesmyslné znaky nahrazují řádek
Posted by: viplex | Date: 2019-08-06 06:56 | IP: IP Logged
No, I am not using TextDiff. I have tried to reproduce it by automatically inserting newlines (and random characters) and removing them again but unfortunately not reproduceable.
This might be slightly unrelated, but I have also seen that some chars are seen as two in the editor, like the emoji grin face (U+1F601) and one can put the cursor between the two chars and type something which then produces [?][?].
What is the best thing I can provide next time I have the encoding issue, hex view?
Posted by: vbr | Date: 2019-08-07 12:20 | IP: IP Logged
viplex:...
I believe, this is a separate problem: the mentioned character is located outside of the Basic Multilingual Plane (BMP) in the unicode standard (characters or code points until U+FFFF).
It seems, PSPad doesn't currently support a correct display of such "more advanced" characters.
(I am not sure, whether the presence of such characters might somhow trigger the buggy behaviour in other places of the file...?)
hth,
Posted by: RANZI | Date: 2019-08-12 10:07 | IP: IP Logged
I use PSPad 5.0.1 (312).
I have the same problem "Line replaced by gibberish characters" after open a text file (718 Ko).
The file on disk hasn't this corrumption (confirm to open with Notepad++).
Found giebberishs are :
I have other gibberish with "ÿ" and "{".
Edited 1 time(s). Last edit at 2019-08-12 10:09 by RANZI.
Posted by: RANZI | Date: 2019-08-14 07:24 | IP: IP Logged
Another case today.
I have this problem more often : 4 times this week
Good luck to find this.
On PC Windows 7 32 bits.
Posted by: RANZI | Date: 2019-08-14 15:00 | IP: IP Logged
This problem seems to happen more often on a line with } (closing brace) and this configuration :
[X]Highlight Matching Brackets
[X]Completion of chars ( [ {
because, I had less often this problem with this configuration :
[ ]Completion of chars ( [ {
Indeed, the software works a lot (laggy) when finding for the end of a missing closing brace.
So, I disable "Highlight Matching Brackets" for my next usage of PSPad.
Edited 1 time(s). Last edit at 2019-08-14 15:03 by RANZI.
Posted by: JL2019 | Date: 2019-08-19 13:33 | IP: IP Logged
+10
Posted by: pspad | Date: 2019-08-20 08:44 | IP: IP Logged
RANZI:This problem seems to happen more often on a line with } (closing brace) and this configuration :
Hello Ranzi
Thank you for your detailed description. I am glad for any info. I will check the code for bracket autocomplete
Posted by: RANZI | Date: 2019-09-09 12:34 | IP: IP Logged
pspad:Hello Ranzi
after 15 days of usage PSPad without bracket autocomplete and without problem, this problem has reappeared 3 times in the same file
Everytime, corruption occurs at the line of a closing bracket ?!
Good luke to find this.
Posted by: RANZI | Date: 2019-09-16 11:58 | IP: IP Logged
To complete my post, I used syntax highlighting in all my anomaly cases.
