You are here: PSPad forum > English discussion forum > Assign shortcut key to browser preview
Goto Page: Previous1 2
#11 Re: Assign shortcut key to browser preview
Posted by: swbrains | Date: 2021-08-05 23:34 | IP: IP Logged
To answer your questions:
When I open a Perl file (*.pl), it does show "Perl" in the editor status bar at the bottom.
This issue occurs in 5.0.7 (675) 64 bit.
#12 Re: Assign shortcut key to browser preview
Posted by: pspad | Date: 2021-08-06 02:59 | IP: IP Logged
What dies it dhows on statusbar?
#13 Re: Assign shortcut key to browser preview
Posted by: swbrains | Date: 2021-08-06 03:19 | IP: IP Logged
When I open an existing Perl file (.pl), this is the info displayed in the status bar:
The key mappings do not work in this case.
Edited 1 time(s). Last edit at 2021-08-06 03:21 by swbrains.
#14 Re: Assign shortcut key to browser preview
Posted by: swbrains | Date: 2021-08-11 16:56 | IP: IP Logged
Any update on this issue when opening an existing file?
#15 Re: Assign shortcut key to browser preview
Posted by: pspad | Date: 2021-08-11 17:17 | IP: IP Logged
I tested it and it works correctly in future build. I am on vacation now this week, please wait for next build
#16 Re: Assign shortcut key to browser preview
Posted by: swbrains | Date: 2021-08-15 00:13 | IP: IP Logged
Thanks. FWIW, I noticed this regarding the issue in 5.0.7:
If I open a .PL file by double-clicking on a file in Windows File Explorer or from FileZilla, it opens the file in PSPad (PSPad is associated with the .PL extension) and the key mappings work fine. I made sure it was opening the 5.0.7 version in this case.
If I open the PSPad 5.0.7 application first without a file using a shortcut on my desktop, THEN use CTRL+O to select a .PL file to open from within PSPad, then key mappings don't work.
Hope this helps!
#17 Re: Assign shortcut key to browser preview
Posted by: pspad | Date: 2021-08-15 16:10 | IP: IP Logged
Thank you, it helps.
I am able to simulate it now.
When I open file after pspad is started, shortcuts don't works. Enough is Ctrl+Space - call code clips list and shortcuts start work.
#18 Re: Assign shortcut key to browser preview
Posted by: swbrains | Date: 2021-08-17 03:51 | IP: IP Logged
The Ctrl+Space trick loads the other highlighter key mappings, but it doesn't load my key mapping to execute the Perl compiler to run a syntax check (F8 on my system).
If I click the word "Perl" in the status bar to bring up the Change Syntax window and then close it without changing anything, then F8 works to run the Perl compiler according to my custom key mappings.
