You are here: PSPad forum > English discussion forum > Re: Please help!
Posted by: pspad | Date: 2020-05-09 08:43 | IP: IP Logged
I tried to explain you your problem using way you should be able to understand. But I see it has no sense.
You got step by step, how to solve your task in spread sheed in few minutes. I guess your did it already.
Posted by: maki | Date: 2020-05-09 11:40 | IP: IP Logged
And if there is no file, so what should I import?
Posted by: pspad | Date: 2020-05-09 12:39 | IP: IP Logged
Copy / paste and save it to file, it isn't so hard...
Posted by: pspad | Date: 2020-05-10 08:51 | IP: IP Logged
Wow. You know already all numbers. It's a good start.
Posted by: Professor Bernd | Date: 2020-05-10 19:48 | IP: IP Logged
@maki
Why do you talk so disrespectfully to the author of PSPad? Please stop bugging us. You get on my nerves!
How old are you? Are you 10 years old? Jesus Christ, can't you understand when you're annoying?
If you think PSPad is so bad, go away!
@PSPad
If you answer maki, it's a waste of time! If you don't answer him, then what? Will he leave the forum? Yay! Why do you answer such a troll, but leave my posts unanswered?
Posted by: maki | Date: 2020-05-10 20:39 | IP: IP Logged
With such a barbaric approach you have it is called fascism, you try to "exclude people", sort according to your own taste. Think about a good rest in the fresh air.
Posted by: feef | Date: 2020-05-11 04:13 | IP: IP Logged
maki:With such a barbaric approach you have it is called fascism, you try to "exclude people", sort according to your own taste. Think about a good rest in the fresh air.
I think You have a lot of time to spend outdoors because you shift your tasks to other people
Posted by: maki | Date: 2020-05-11 06:34 | IP: IP Logged
Don't forget about doing good and sharing what you have with others, because it gives you greater pleasure.
