You are here: PSPad forum > English discussion forum > Main menue ALT-Hotkeys not functional at German language
Goto Page: 1 2 Next
#1 Main menue ALT-Hotkeys not functional at German language
Posted by: hhoefling | Date: 2020-03-22 14:40 | IP: IP Logged
In German Language no ALT- Hotkey will go.
Nothing none.
Only the underline Char will show up at keypress of Alt Key.
In English all is ok.
by HH
#2 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: Professor Bernd | Date: 2020-03-28 15:28 | IP: IP Logged
Hi Heinz (Landsmann) winking smiley
Which PSPad version do you use? The "Alt" shortcuts work for me in Version 5.0.3(337) and 5.0.4(381).
Bernd.
#3 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: hhoefling | Date: 2020-03-28 18:30 | IP: IP Logged
5.0.3(363) 64b on W10/1909
The Menu doesnt pull down at ALT Key Pressed.
Only the Underline show's up
by HH
#4 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: hhoefling | Date: 2020-03-28 18:47 | IP: IP Logged
I found the reason....
I there is an HotKey with the same Chr then the Alt-Menu doesn't puls down.
Sample:
Alt-D (for the first Main-Menue "&Datei) has the same Key as "Insert-Date" Hotkey.
After removing the Hotkey, the Main-Menu ist pulls down after Alt-D
Now i ust search for all Alt-Key in the Keyboard setting..... sad smiley
by HH
#5 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: Professor Bernd | Date: 2020-03-28 23:59 | IP: IP Logged
Yeah, shortcuts are a rare commodity. I'm glad you found the bug. smiling smiley
Bernd.
#6 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: pspad | Date: 2020-03-29 06:47 | IP: IP Logged
There is necessary to modify german localization file and change hotkeynletters
#7 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: Professor Bernd | Date: 2020-03-29 15:49 | IP: IP Logged
Do you mean the "Deutsch.ini" with the ";;Translate" parts?
#8 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: pspad | Date: 2020-03-29 16:04 | IP: IP Logged
Yes, I mean Deutch.ini, section [Main menu]
e.g.
mFile_Caption=&File
char & means that letter F is hotkey.
#9 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: Professor Bernd | Date: 2020-03-29 16:28 | IP: IP Logged
Okay, I see what you mean about the hotkeys. Thank you. smiling smiley
Do you still need a translation of the missing passages in the Deutsch.ini, or do you already have one?
#10 Re: Main menue ALT-Hotkeys not functional at German language
Posted by: Stefan | Date: 2020-07-09 16:48 | IP: IP Logged
Please note:
-For menu item like first Menu "&Datei" (Alt,D)
press and release the Alt+key, next press D
-For non-menu shortcuts like command "Insert-Date", use Alt+D together
- The shortcuts for the menu are defined in the language.ini (Deutsch.ini)
mFile_Caption=&Datei >>>> Alt,D
I have the one for the main menu collected here for you below.
- The shortcuts for the commands are defined via configuration dialog:
Einstellungen > Programm einstellen... >> Tastaturbelegung >>> Insert
>>>> Datum und Zeit einfügen - - - Alt+D
(BTW: The shortcuts for the script are defined inside of the scripts itself)
PSPad\Language\Deutsch.ini
[Main Menu]
mProject_Caption=&Projekt
mEdit_Caption=&Bearbeiten
mFind_Caption=&Suchen
mView_Caption=&Ansicht
mFormat_Caption=&Format
mEncoding_Caption=Kodierung >> K&odierung <<will be available in the next but one beta build
mTools_Caption=W&erkzeuge
mScripts_Caption=S&kripte
mHTML_Caption=&HTML
mSettings_Caption=E&instellungen
mWindow_Caption=Fe&nster
mHelp_Caption=Hi&lfe
D P B S A F O E K H I N L
Edited 1 time(s). Last edit at 2020-07-09 16:56 by Stefan.
Goto Page: 1 2 Next
