You are here: PSPad forum > English discussion forum > Re: Searching and deleting lots of unnecessary files.
Posted by: maki | Date: 2020-01-11 19:42 | IP: IP Logged
Example. I have a lot of html files.
I want to find all files that contain code:
<font color="#FF0000">Ошибка 404: такой страницы на сервере нет</font>
AND
<h1 align="center">Произведение</h1>
If a file contains this code, I want to delete all of these files.
Maximum size html file: 1KB - 9KB
Edited 2 time(s). Last edit at 2020-01-11 19:46 by maki.
Posted by: pspad | Date: 2020-01-11 20:00 | IP: IP Logged
Use file manager. This isn't job of text editor
You can use Explorer what is part of Windows. It can do this job too.
Posted by: maki | Date: 2020-01-11 20:47 | IP: IP Logged
Hm.
I have a advanced search application.
Find: regex
File Types: *.html
Encoding:
Configured Encoding: 1251 (Cyrylic???)
I just need the regular expression for these two codes.
<font color="#FF0000">Ошибка 404: такой страницы на сервере нет</font>|<h1 align="center">Произведение</h1>
Edited 2 time(s). Last edit at 2020-01-11 20:56 by maki.
Posted by: maki | Date: 2020-01-11 20:58 | IP: IP Logged
Edit:
Solved.
Now, I have a list of unnecessary file names.
Now how do delete all files by this name list?
2019_01_01_1726.html(26): <h1 align="center"><font color="#FF0000">Ошибка 404: такой страницы на сервере нет</font></h1>
I can add names as regex, but it will be too long regex. No optimization.
The application has strengthening.
Unlimited regex length, even a trillion names, but a 100% CPU process all the time to complete.
Edited 1 time(s). Last edit at 2020-01-11 21:01 by maki.
Posted by: maki | Date: 2020-01-11 21:17 | IP: IP Logged
I made searching for unnecessary files a bit easier.
The files have similar file sizes.
The risk of error is minimal, that you accidentally delete a good file.
Regex: (2[0-8][0-9]{2}|29[0-8][0-9]|299[0-9])\.html
Edited 1 time(s). Last edit at 2020-01-11 21:21 by maki.
