You are here: PSPad forum > English discussion forum > PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Goto Page: Previous1 2
#11 Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: pspad | Date: 2019-12-28 16:36 | IP: IP Logged
maki:
NON-Stop crash Find / Replace
And always Lost Profile / all Tabs
i.postimg.cc
If you want to load profile, first save one, then choose it from the list and then press load button.
This isn't search box, upper part in dialog serves as search/replace profile storrage.
If you don't want to use it, forget it.
#12 Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: pspad | Date: 2019-12-28 16:38 | IP: IP Logged
Close all PSPad, open Task manager and check if there isn't any running instance.
#13 Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: maki | Date: 2019-12-28 16:42 | IP: IP Logged
C:\Users\XXX\AppData\Roaming\PSpad\Recent.INI
Quote:
[Find/Replace config]
Case sensitive=0
Whole words=0
Ask replace=0
Add LineNum=0
Entire Scope=0
RegExp=0
Width=580
[Clip Window]
Height=243
Width=422
[Insert text start]
Item0=https://www.
Item1=https://www.
Item2=www
[Insert text end]
Item0=.jd
[Find/Replace find history]
Item0=.jd
Item1=avtor
Item2=PR
[Find/Replace replace history]
Item0=example
Nothing can be done, I have crashes all the time, sometimes it shows a failure, after a failure, an infinite process, an infinite number of errors and a lack of memory in the system. Too many errors.
Edited 1 time(s). Last edit at 2019-12-28 16:43 by maki.
#14 Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: pspad | Date: 2019-12-28 16:51 | IP: IP Logged
have you did what I suggested to you? have you checked if there is no hidden running instance of PSPad in the task manager?
#15 Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: pspad | Date: 2019-12-28 16:53 | IP: IP Logged
Download this archive:
leteckaposta.cz
It's future PSpad 5.0.3 build.
Unpack PSPad.exe and language folder and replace existing installation.
#16 Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: maki | Date: 2019-12-28 16:59 | IP: IP Logged
I have installed version 5.0.3 There is currently no error.
