You are here: PSPad forum > English discussion forum > Re: PSPad.exe, 5.0.2.349 0x0EEDFADE" error
Posted by: pspad | Date: 2019-12-28 16:36 | IP: IP Logged
maki:
If you want to load profile, first save one, then choose it from the list and then press load button.
This isn't search box, upper part in dialog serves as search/replace profile storrage.
If you don't want to use it, forget it.
Posted by: pspad | Date: 2019-12-28 16:38 | IP: IP Logged
Close all PSPad, open Task manager and check if there isn't any running instance.
Posted by: maki | Date: 2019-12-28 16:42 | IP: IP Logged
C:\Users\XXX\AppData\Roaming\PSpad\Recent.INI
Quote:[Find/Replace config]
Case sensitive=0
Whole words=0
Ask replace=0
Add LineNum=0
Entire Scope=0
RegExp=0
Width=580[Clip Window]
Height=243
Width=422[Insert text start]
Item0=https://www.
Item1=https://www.
Item2=www[Insert text end]
Item0=.jd[Find/Replace find history]
Item0=.jd
Item1=avtor
Item2=PR[Find/Replace replace history]
Item0=example
Nothing can be done, I have crashes all the time, sometimes it shows a failure, after a failure, an infinite process, an infinite number of errors and a lack of memory in the system. Too many errors.
Edited 1 time(s). Last edit at 2019-12-28 16:43 by maki.
Posted by: pspad | Date: 2019-12-28 16:51 | IP: IP Logged
have you did what I suggested to you? have you checked if there is no hidden running instance of PSPad in the task manager?
Posted by: pspad | Date: 2019-12-28 16:53 | IP: IP Logged
Download this archive:
leteckaposta.cz
It's future PSpad 5.0.3 build.
Unpack PSPad.exe and language folder and replace existing installation.
Posted by: maki | Date: 2019-12-28 16:59 | IP: IP Logged
I have installed version 5.0.3 There is currently no error.
