You are here: PSPad forum > English discussion forum > Re: How to Create List?
Posted by: pspad | Date: 2019-12-28 16:23 | IP: IP Logged
I added "step" into insert text to line function. I though it already exists there.
Will be available in the next build
Posted by: joemarfice | Date: 2020-01-04 16:05 | IP: IP Logged
<wrong thread>
Edited 1 time(s). Last edit at 2020-01-04 16:06 by joemarfice.
Posted by: maki | Date: 2020-01-07 01:51 | IP: IP Logged
It does not work properly in PSPad.
Adds numbers at the beginning. Cannot change: Add at the end of each line
Wrong:
0URL
50URL
100URL
150URL
200URL
I want:
URL0
URL50
URL100
URL150
URL200
Posted by: pspad | Date: 2020-01-07 04:13 | IP: IP Logged
Add numbers first
Then add text
I see you don'!t know how to read. See my first answer in this thread
Quote:In 2 steps using Alt+I:
1. generate list of numbers and select it
2. insert text for all lines into begin
Edited 1 time(s). Last edit at 2020-01-07 04:27 by pspad.
Posted by: maki | Date: 2020-01-07 14:43 | IP: IP Logged
[quote=pspad]
Add numbers first
Then add text
[quote]In 2 steps using Alt+I:
[/quote]
PSPad 5.0.3 (360)
I tried to add:
Numbering - SET - OK
Generates nothing - empty!
Posted by: pspad | Date: 2020-01-07 15:26 | IP: IP Logged
Again. Insert text to line works with selected lines.
If you have empty file, it has nothing to insert into lines.
Make as much empty lines as you need
Select all (Ctrl+A)
Continue with numbering
Posted by: maki | Date: 2020-01-07 20:14 | IP: IP Logged
What? This is bore job. Too many steps. And I can't spend all this time on it. This is not practical.
Set numbers. 1 click OK. I already have a generated list. Simple. This is how it should look like.
Posted by: pspad | Date: 2020-01-07 20:27 | IP: IP Logged
You wrote you won't use PSPad so another adds has no sense. Please leave this forum.
