You are here: PSPad forum > English discussion forum > Language help doesn't work if caret is directly after the search term
Posted by: Professor Bernd | Date: 2019-10-14 02:34 | IP: IP Logged
I beg your pardon, if that has already been asked.
In the editor I often start to write a word, e.g. "msg". Then I use the autocompletion, and "MsgBox" is inserted with the caret directly behind it. Then I press Alt+F1 for language help. The help opens, but not with the search term.
If I set the caret only 1 character to the left, everything works fine, the help is displayed with the search term.
Is there a setting so that it also works if the caret is at the right end of the search term?
Posted by: pspad | Date: 2019-10-25 08:25 | IP: IP Logged
Modification was done. Word under cursor will be returned even cursor is behind the word.
Available in the next build. I will try to publish it as soon as possible
Posted by: Professor Bernd | Date: 2019-10-25 13:15 | IP: IP Logged
Great. Thank you very much!
Will the shortcuts for fav tools also be available? That would help me a lot.
Posted by: pspad | Date: 2019-10-25 13:38 | IP: IP Logged
All ideas are in the list. I had to finish search/replace profiles.
Now new build is out already and I will work on another requests.
