You are here: PSPad forum > English discussion forum > How do you find all the numbers that are most often repeated in a set?
#1 How do you find all the numbers that are most often repeated in a set?
Posted by: maki | Date: 2019-06-29 12:30 | IP: IP Logged
For example, I want to find all five in sets or tens. Unfortunately, this is not possible due to the limitations of programs, they can not process so much data. And they return for each error and failure.
L1 to L20
i.postimg.cc
#2 Re: How do you find all the numbers that are most often repeated in a set?
Posted by: pspad | Date: 2019-06-29 16:50 | IP: IP Logged
You want to do statiscitcs in text editor?
Use program what suits your request, e.g. Excel or Libre Calc. It has analytics and statistics functions
#3 Re: How do you find all the numbers that are most often repeated in a set?
Posted by: DeborahWebb | Date: 2019-07-16 09:31 | IP: IP Logged
Finding the Mode of a Data Set
Finding the Mode in Special Cases
#4 Re: How do you find all the numbers that are most often repeated in a set?
Posted by: DeborahWebb | Date: 2019-07-18 07:57 | IP: IP Logged
l got two easy ways to find all the numbers that are most often repeated in a set:
1. Finding the Mode of a Data Set
2. Finding the Mode in Special Cases
And here are detailed steps l'd love to share with your guys;docsbay.net
#5 Re: How do you find all the numbers that are most often repeated in a set?
Posted by: maki | Date: 2019-07-19 06:55 | IP: IP Logged
What is this for some complicated hieroglyphics? I'm not a mathematician.
I do not understand these operations:
translate.google.com
Edited 3 time(s). Last edit at 2019-07-19 07:03 by maki.
