You are here: PSPad forum > English discussion forum > Where is the simple option: "Reverse"?
Posted by: Vany | Date: 2019-06-23 00:20 | IP: IP Logged
Hi, okay, I did it for myself formerly, but you could try my own script - just download and unpack it into the PSPad folder \Script\vbscript
(probably c:\Program Files (x86)\PSPad editor\Script\VBScript\)
the Vany submenu in the Scripts menu will appear
(PSPad 5.0.7 (751) x32, W10h/p x64 en/cs)
Posted by: maki | Date: 2019-06-23 06:30 | IP: IP Logged
I was looking for this Menu script in the program because it was not by default. I have enabled this option, only temporarily you can enable the option that does not work anyway. Ie. this script can not be run.
EmEditor 5.0.0 64-bit
Posted by: pspad | Date: 2019-06-23 07:11 | IP: IP Logged
Use 32b version
Posted by: maki | Date: 2019-06-23 15:33 | IP: IP Logged
@PSPad - Now, use 32bit
@Vany - It does not work as expected, it reverses the numbers.
Ex. 09,01 -> 10,90
Total wrong
Shouldbe:
09=09
Not:
09=90
Edited 2 time(s). Last edit at 2019-06-23 15:36 by maki.
Posted by: maki | Date: 2019-06-25 12:20 | IP: IP Logged
I am looking for the "Reverse Number Order" tool
Posted by: Vany | Date: 2019-06-28 08:55 | IP: IP Logged
so try the other options, for example reverse pairs by comma
Posted by: Vany | Date: 2019-07-01 12:09 | IP: IP Logged
Reverse String By Comma - does the work for you
01,90,42 => 42,90,01
Reverse String By Dot - e.g. for IP addresses
192.168.0.1 => 1.0.168.192
Reverse String Dbl Char - e.g. for HEX strings
AAFF11 => 11FFAA
Posted by: maki | Date: 2019-07-01 21:16 | IP: IP Logged
It works fine here, but add other separators
01;76;66;32;43
Edited 1 time(s). Last edit at 2019-07-01 21:16 by maki.
Posted by: pspad | Date: 2019-07-02 04:37 | IP: IP Logged
Naki, you have script with several separators, You are not able to add another? Copy/Paste is too hard?
Posted by: Vany | Date: 2019-07-02 08:12 | IP: IP Logged
don't you want to add the word PLEASE ?
you are not our boss, you are our colleague, so please be so kind and remember it and behave like it
we have no problem to add it for you, but don't try to order or force us
