You are here: PSPad forum > English discussion forum > Where is the simple option: "Reverse"?
Posted by: maki | Date: 2019-06-17 14:08 | IP: IP Logged
Example: 01,56,79 -> 79,56,01
Edited 1 time(s). Last edit at 2019-06-17 14:09 by maki.
Posted by: pspad | Date: 2019-06-17 14:30 | IP: IP Logged
Sorry, but it isn't reverze.
Reverse is: 01,56,79 -> 97,65,10
If you want to take list of values, delimited by some char and create reverse order of values, write script for it.
Of if number of values is constant and limited e.g. by 9, you can use regular expressions.
Posted by: maki | Date: 2019-06-17 18:26 | IP: IP Logged
But I'm not a scriptwriter or programmer.
Reverses every number, which is completely wrong!
Edited 1 time(s). Last edit at 2019-06-17 18:33 by maki.
Posted by: pspad | Date: 2019-06-17 18:48 | IP: IP Logged
First step: you need to make a list delimited strings
Second step: you will reverse strings order
Third step: you will create delimited list of strings
Why don't you use regular expressions? You can use user
convertors to create one click reverse string without programming knowledges
Edited 1 time(s). Last edit at 2019-06-17 18:49 by pspad.
Posted by: maki | Date: 2019-06-17 22:49 | IP: IP Logged
It's just that it does not work for me:
^([^,]*)\,(\d+)$
Posted by: pspad | Date: 2019-06-18 02:49 | IP: IP Logged
(\d+), (\d+),(\d+),(\d+)
$4,$3,$2,$1
Posted by: Stefan | Date: 2019-06-19 08:28 | IP: IP Logged
01,56,79
TO:
79,56,01
USE:
Ctrl+H
Search: (\d\d),(\d\d),(\d\d)
Replace: $3,$2,$1
[x]RegEx
Posted by: maki | Date: 2019-06-21 07:25 | IP: IP Logged
pspad:(\d+), (\d+),(\d+),(\d+)
$4,$3,$2,$1
But it works only with a defined set of numbers. It will not work for a different set. It does not look good if I had to modify it every time. Still need to improve it so that it can work on every set of numbers.
Posted by: pspad | Date: 2019-06-21 11:19 | IP: IP Logged
maki:But it works only with a defined set of numbers. It will not work for a different set. It does not look good if I had to modify it every time. Still need to improve it so that it can work on every set of numbers.
You can use user convertors and define several convertors for different numbers.
Or you can try to write own script. I wrote you steps you need to do in the script
Posted by: maki | Date: 2019-06-21 11:37 | IP: IP Logged
You can always find scripts on the programming page, but first you need to know how to use, for example, java script, c++, or many more. In my life I wrote only a few simple scripts, and I do not have too extensive knowledge on this subject.
#include <stdio.h>
int main()
int n, reversedNumber = 0, remainder;
printf("Enter an integer: ");
scanf("%d", &n);
while(n != 0)
remainder = n%10;
reversedNumber = reversedNumber*10 + remainder;
n /= 10;
printf("Reversed Number = %d", reversedNumber);
return 0;
