You are here: PSPad forum > English discussion forum > Re: How to get rid of this unwanted line?
Goto Page: Previous1 2
#11 Re: How to get rid of this unwanted line?
Posted by: maki | Date: 2019-03-29 22:47 | IP: IP Logged
As you do not understand - It is difficult to.
#12 Re: How to get rid of this unwanted line?
Posted by: pspad | Date: 2019-03-30 05:44 | IP: IP Logged
Yes, cause you jump from one thing to second, paste screenshots from different apllications without any note, ask again and again about same thing even it was several times answered.
Your questions contain few words without context.
I will answer question what has sense. If any question will stay without answer, it will be sign for you that question, as you wrote it can't be answered without explanation.
Edited 1 time(s). Last edit at 2019-03-30 05:45 by pspad.
#13 Re: How to get rid of this unwanted line?
Posted by: maki | Date: 2019-03-30 08:09 | IP: IP Logged
Here are my settings yawning smiley. How to set a Margin Line equal to 80?
If in PSPad: Setting -> Right Margin 80 (or 0 or 2000)
Probably the "Margin Line" option is missing
"Margin Line" and "Right Margin" <=== This is not the same
Edited 5 time(s). Last edit at 2019-03-30 08:16 by maki.
#14 Re: How to get rid of this unwanted line?
Posted by: pspad | Date: 2019-03-30 09:30 | IP: IP Logged
Another useless topic. It's same as I will send you settings screenshot in czech language. Now you need to wait for Chinese speaking user.
Another possibility is run PSpad help and read how to set right margin.
And as the last switch PSPad interface to English and find option: Position of right edge
#15 Re: How to get rid of this unwanted line?
Posted by: pspad | Date: 2019-03-30 09:33 | IP: IP Logged
Take it as warning. If I will get convinced that you waste time of others and make fun of them, I will lock your account.
#16 Re: How to get rid of this unwanted line?
Posted by: maki | Date: 2019-03-30 13:14 | IP: IP Logged
I have read the help file from the beginning to the end. I found nothing. At least that's not what I mean. You set the margin, but the text still exceeds it. Screenshot, like a normal screenshot of settings, the same values in English, it's too easy to not take it intuitively.
But good, as you think, you can scare a ban? Should I worry about it?
can not set up as I expect and I also asked in advanced others forums.
Edited 3 time(s). Last edit at 2019-03-30 13:21 by maki.
#17 Re: How to get rid of this unwanted line?
Posted by: maki | Date: 2019-03-30 15:05 | IP: IP Logged
I found this setting in Editor 1.
It works.
Now how to get rid of this icon "Wrap" on the left, mixed with the numbering of lines, and the numbers are hardly noticeable.
Edited 1 time(s). Last edit at 2019-03-30 15:07 by maki.
#18 Re: How to get rid of this unwanted line?
Posted by: pspad | Date: 2019-03-30 15:51 | IP: IP Logged
This icon identify, tak it's one line and it's wrapped.
You can wrap lines permanently - Menu Format / Block format / Reformat paragraph.
