You are here: PSPad forum > English discussion forum > Files do not open
Posted by: pspad | Date: 2011-12-13 10:12 | IP: IP Logged
Can you please download the latest build from PSPad developer forum and replace existing PSPad.EXE
Go to program settings, unregister PSpad, confirm, register it again and confirm.
Posted by: Blues48 | Date: 2011-12-14 09:33 | IP: IP Logged
Ok, I got it to work on my Vista32, multi-user enabled, not running as portable. However: If I run PsPad with Admin-rights (under an otherwise restricted user account) I experience the same problem again: Cannot add files by any other method than directly from within a running PSPad.
In other words: Everything is fine now as long as I run PsPad with regular (restricted) user rights.
If I run it with admin-rights, my normal user-environment is not able to add files to the running instance (started with admin rights)
PsPad resides under C:\Program Files
Its settings under User\AppData\Roaming
Posted by: pspad | Date: 2011-12-14 09:56 | IP: IP Logged
From Windows Vista, MS add folder virtualization - I don't like it.
applicatio ndoesn't know now that somwthing is wrong, that it can't write into specific folder, cause Windows virtualize this folder and let application write there.
PSPad offer you 2 modes:
Multiuser - this is correct mode if PSpad is installed in program files and works without any problem in Windows
Portable mode - for using on flashdisks or in case when you want to have all PSpad in one folder. In this case isn't possible to install it into Program files.
Personally, I created new folder \Programs and I have there portable applications. When I need to reinstall OS or change computer, I can simple copy this folder and all applications work for me. It spares me really lot of time.
Posted by: Blues48 | Date: 2011-12-14 11:49 | IP: IP Logged
I know what you mean, Jan, and I totally agree: Virtualized folders give an application the false idea that it is writing to the intended directory, whereas in reality the changes end up somewhere else.
Starting up portable from E:\JustRun\PsPad seems a good idea.
I de-installed PsPad, but the context menus remained there. I can't get rid of them. Disabling the checkboxes in System Integration (then Apply, OK, then re-booting) didn't help, Do you know of any tool to remove those shell entries?
Posted by: pspad | Date: 2011-12-14 12:02 | IP: IP Logged
Blues48:I know what you mean, Jan, and I totally agree: Virtualized folders give an application the false idea that it is writing to the intended directory, whereas in reality the changes end up somewhere else.Starting up portable from E:\JustRun\PsPad seems a good idea.
Try to run PSPad as administrator and then uncheck context menu items in Program settings / System.
Sometimes reboot is necessary, cause if context menu is in use, uninstaller can't remove it. It will mark it to remove it after start.
PSpad contains Support folder, where are 2 batch files for register and deregister (run it as administrator) Windows explorer extension, if you had PSPad integrated with shell extension.
Posted by: reiet | Date: 2011-12-14 17:07 | IP: IP Logged
Ok, I've tried with:
· Assign all privileges on folder PSPAD
· Open the pspad editor as administrator
· Go to settings/system
· unregister PSPad from context menu & confirm
· close de program
· register PSPad from context menu & confirm
Voilà!
Posted by: Blues48 | Date: 2011-12-14 17:47 | IP: IP Logged
Aaah - big sigh of relief - it works now.
Here's what I did:
- Had to manually run the Shell_unregister batch file to get rid of the context menu
- then unpack the portable version into my JustRun folder
- then run Shell_reg.bat to re-introduce the context menus (applying it from PsPad settings > system integration would not do the trick)
Posted by: samikrc | Date: 2012-01-28 23:04 | IP: IP Logged
This only works for the context menu, i.e., if I right click on a file and select 'PSPad', then the file correctly works in PSPad. Still doesn't work for double clicking a file. Win 7 x64.
reiet:Ok, I've tried with:· Assign all privileges on folder PSPAD
· close de program
· register PSPad from context menu & confirmVoilà!
Posted by: samikrc | Date: 2012-01-28 23:08 | IP: IP Logged
To clarify, for me, opening a file with PSPad doesn't work at all when I double click the file, irrespective of whether PSPad is open at the time or not. If the PSPad is not open, PSPad opens up with 'New1.txt', i.e., a blank file. If the PSPad is already open, nothing happens.
Only thing that works is the 'PSPad' context menu.
Hope this gets resolved soon.
Posted by: samikrc | Date: 2012-01-28 23:18 | IP: IP Logged
OK - jumped the gun a little early. Opening PSPad as Administrator, and registering the file types in Settings -> Register file types seems to make the problem go away.
Hope this helps someone.
samikrc:To clarify, for me, opening a file with PSPad doesn't work at all when I double click the file, irrespective of whether PSPad is open at the time or not. If the PSPad is not open, PSPad opens up with 'New1.txt', i.e., a blank file. If the PSPad is already open, nothing happens.
Only thing that works is the 'PSPad' context menu.Hope this gets resolved soon.
