You are here: PSPad forum > English discussion forum > Multi-Search
Posted by: maki | Date: 2014-10-02 17:20 | IP: IP Logged
How do I find a few links OR PATH at the same time and add it to a new window? (Multi-Search)
Example:
Add [LIST] Search:
PATH:
1. F:\Folder\Folder\file....
2. C:\......
3....
4..
OR
Links
1. Hxxp : \\ .......
2...
3...
and COPY (result NEW TAB)
Edited 2 time(s). Last edit at 2014-10-02 17:21 by maki.
Posted by: pspad | Date: 2014-10-02 17:49 | IP: IP Logged
Use Find/Replace dialog
Write regular expression to find your file or URL
Press COPY button to copy files or links into new file
Posted by: maki | Date: 2014-10-03 08:13 | IP: IP Logged
You can not add more than one line !!!
How to add a list of 100 links to search in an open document?
Edited 1 time(s). Last edit at 2014-10-03 08:13 by maki.
Posted by: Stefan | Date: 2014-10-03 10:25 | IP: IP Logged
The trick is to not have a list, but search lines by common pattern.
If you have a list already, why you have to search for?
If you really want to search for literal strings, just learn how to write a script
and use that to parse the file and extract the wanted lines.
Or use a command line tool as SED, AWK or PoSh.
A text editors' search&replace is not the right tool for you.
Posted by: maki | Date: 2014-10-03 10:41 | IP: IP Logged
I want to find in a text file (where you saved the file names) specified names!
What is the simplest, best tool you suggest?
No scripts, no combining, only a program.
What program has Muli-Search?
ONLY Search for all file names in a text file.
Not replace
Not edit
No other unnecessary operations on text file
There is in the world any text editor with Multi-Search?
Edited 2 time(s). Last edit at 2014-10-03 10:45 by maki.
Posted by: maki | Date: 2014-10-03 10:55 | IP: IP Logged
No command, No Unix(SED) .. I'm not a programmer, I'm a little-advanced user
how to find at the same time 4000 different names in a text file, and copy full names? Tutorial ...
The list is very long, a shortened version of the sample
ADD LIST FIND NAMES
D:\NAZWA\FOLDER GDDV\20000928750_0\e_c32cd4f8.jpg
N:\1\Polska RYSUNKI ALL!!\20000928750_0\e_c3c220ff.jpg
N:\1\GHYTFD RYSUNKI \20000928750_0\c4f78365.jpg
N:\1\Polska RYSUNKI ALL!!\20000928750_0\e_cbd3a91e.jpg
N:\1\Polska RYSUNKI ALL!!\20000928750_0\e_d8b31c7b.jpg
N:\1\Polska RYSUNKI ALL!!\20000928750_0\ebc61d96.jpg
EXAMPLE:
Result ALL Find:
Edited 2 time(s). Last edit at 2014-10-03 11:04 by maki.
Posted by: maki | Date: 2014-10-03 11:14 | IP: IP Logged
I'm talking about...Text crawler...
Posted by: Stefan | Date: 2014-10-03 12:32 | IP: IP Logged
Quoted to prevent from modifications.
maki:No command, No Unix(SED) .. I'm not a programmer, I'm a little-advanced userhow to find at the same time 4000 different names in a text file, and copy full names? Tutorial ...
ADD LIST FIND NAMES
e_cbd3a91e.jpgThe list is very long, a shortened version of the sample
N:\1\Polska RYSUNKI ALL!!\20000928750_0\ebc61d96.jpgEXAMPLE:
Result ALL Find:
At least you provide now some usable examples, fine!
That can be done with PSPad and 'OR'ed RegEx pattern,
but need some work on your side,
and will not work for a very long list of search pattern,
but for a few only (you have to test how many will work)
Steps:
Manipulate your "ADD LIST FIND NAMES" list
1.) by adding "^.+" at begin and "$|" at the end of each line.
Use "Edit > Lines Manipulation > Insert Text into Lines..."
Begin: ^.+
End: $|
2.) Next, join this lines together:
Select all lines.
Use "Edit > Lines Manipulation > Join Lines"
3.) Clean up that line by removing the extra added space from the joining:
Search: ^ |
Replace: ^|
[_]RegEx disabled
Now use this line as RegEx search pattern on your text file:
Search: ^.+ebc61d96.jpg$|^.+e_c3c220ff.jpg$|^.+e_cbd3a91e.jpg$|
[X]RegEx enabled
Press the [Copy] button.
Done!
That above works for your provided examples.
If this will not work for you, read a good RegEx tutorial, or go searching for a better tool to suit you.
Posted by: maki | Date: 2014-10-03 12:52 | IP: IP Logged
Oh My God. Patern, Regex, Edit, Search and other... This is a toy for preschooler
This solution is complicated and not very fast (if anything is changed multiple times in the list)
I would like to edit something but many times, quickly
I would like the program to have the option "Load List"
1. Load List.
2. Find All
3. Done! EASY and extreme fast ??? :D
but it does not work in PSPad so easily, you need the magic option.
Edited 4 time(s). Last edit at 2014-10-03 12:58 by maki.
