You are here: PSPad forum > English discussion forum > Multi-Search
Posted by: maki | Date: 2014-10-05 07:21 | IP: IP Logged
I added a list (Tested on a larger list - 400 MB)
I typed regex to search
but did not find.
I do not know why.
Posted by: Stefan | Date: 2014-10-05 07:56 | IP: IP Logged
maki:I added a list (Tested on a larger list - 400 MB)
but did not find.
I do not know why.
unbelievable
he is incompetent to understand even the simplest basics, even if we point him to the right direction
perhaps this all is a psychotropic experiment of a student only and we are the object
or this is the matrix
Posted by: Stefan | Date: 2014-10-05 07:58 | IP: IP Logged
maki:Without regex
Without scriptSolved. I have used other better editor 100% work.
Find all names 1 second !!!!! superfast!
So you told us everything was done already.
Case closed here.
Please register to the EditPad Pro forum to ask for further advice.
Thank you for using PSPad. I am glad you found something better. Far well makinator.
@Jan Goyvaerts: good luck
Edited 2 time(s). Last edit at 2014-10-05 08:03 by Stefan.
Posted by: maki | Date: 2014-10-05 08:11 | IP: IP Logged
1. There is no such "FREE" forum EditPad
I use "Lite version" "Lite"(free) version not support forum.
2. I have tested only the whole string line and worked an 100%
3. Tested individual names in the text and NOT WORK because..Probably should be select, to set something in the program but do not know what.
Edited 4 time(s). Last edit at 2014-10-05 08:15 by maki.
Posted by: maki | Date: 2014-10-05 08:23 | IP: IP Logged
Works only whole words.
It does not work with individual names
Ech... :\ Please, please, please, please, please help
Edited 1 time(s). Last edit at 2014-10-05 08:26 by maki.
Posted by: naputtelija | Date: 2014-10-05 08:35 | IP: IP Logged
You need to learn regular expressions before you can use them: www.regular-expressions.info
Posted by: pspad | Date: 2014-10-05 08:36 | IP: IP Logged
I am sorry, but I don't know what do you mean.
And I don't know the tool you are using (the forward window on your picture). Did you try to ask it's authors?
Posted by: Stefan | Date: 2014-10-05 08:37 | IP: IP Logged
Press F1 key while in EditPad: Read - Test - Try to understand - read again
Posted by: pspad | Date: 2014-10-05 08:40 | IP: IP Logged
naputtelija:You need to learn regular expressions before you can use them: www.regular-expressions.info
It's hard, cause present schools doesn't teach nothing except copy/paste. They don't teach students to think, to learn themselves, explain them things, give them examples. I see it on my daughter.
Posted by: maki | Date: 2014-10-05 08:43 | IP: IP Logged
Stefan & pspad
F1 Help
Sorry but the software sucks.
I wrote the correct regex.
Works only Search / Replace
It does not work Search / Copy lines
Edited 1 time(s). Last edit at 2014-10-05 08:43 by maki.
